Author Topic: letter case in Computer Name  (Read 5903 times)
MeasureUp
« on: November 26, 2012, 06:38:07 PM »
I set my computer name as "WorkStation_05".
It can be found in control panel -> System.
But (getenv "computername") returns as "WORKSTATION_05".
How can I get the variable as "WorkStation_05" without it all in upper case?
Thanks for your help.
MeasureUp
Re: letter case in Computer Name
« Reply #1 on: November 26, 2012, 09:25:36 PM »
I think this is something on the windows setting.
irneb
« Reply #2 on: November 27, 2012, 12:30:32 AM »
That's probably correct. There might be some other registry code showing the name with lower case letters as well. You could try searching for such through RegEdit.
« Reply #3 on: November 27, 2012, 10:19:19 AM »
What does this return:
  1. (vlax-get (vlax-get-or-create-object "WScript.Network") 'computername)
MeasureUp
« Reply #4 on: November 27, 2012, 05:44:06 PM »
To ronjonp:
It returns the computer name with all upper case letters.
To irneb:
Sorry, I turned on the "regedit" dialog box but I know nothing about searching registry.
« Reply #5 on: November 27, 2012, 06:02:30 PM »
The Computer Name is found in the registry under:
HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\ComputerName\\ComputerName
However, I am unsure where the lower-case version (as displayed in the System Properties) is found, if indeed it resides in the registry at all... :|
« Reply #7 on: November 27, 2012, 06:32:15 PM »
After a quick search on Google, I stumbled across this thread:
http://www.quickmacros.com/forum/viewtopic.php?f=1&t=5256
Which appears to indicate that the use of this function:
http://msdn.microsoft.com/en-gb/library/windows/desktop/ms724301%28v=vs.85%29.aspx
yields the desired lowercase result.
And since the MSDN documentation states:
The names are established at system startup, when the system reads them from the registry.
This seems to confirm that the values are indeed stored somewhere in the registry, but I have no clue where... maybe someone else can carry the baton from here.
irneb
« Reply #8 on: November 27, 2012, 11:24:17 PM »
To irneb:
Sorry, none of my PC's/Laptops have lowercase letters in their names - so I can't actually search myself.
While you've got the RegEdit (Registry Editor) open, click Edit --> Find ... (or Ctrl+F). Type the computer's name & click OK. Press F3 to continue the search until you find a key with the lowercase letters, then note the path listed in RegEdit's status bar (you can also right-click on a key in the tree on the left then "Copy Key Name" - gives the full path).
MeasureUp
« Reply #9 on: November 27, 2012, 11:50:31 PM »
To irneb,
Thank you again.
I've just done something before reading your post.
These are what I've done:
1) (setenv "computername" "WorkStation_05")
2) (setenv "setcomputername" "WorkStation_05")
I have to change 2 env variables because if the value of one of them doesn't affect the other.
And it works perfectly!
And certainly thanks to Lee Mac and other guys who gave their tips.
