Author Topic: Which is better way?  (Read 1909 times)
HasanCAD
« on: May 09, 2011, 10:25:43 AM »
This method
(list
  (+ (nth 0 (cadr pt1)) (nth 0 (cdr (cadr pt2))))
  (+ (nth 1 (cadr pt1)) (nth 1 (cdr (cadr pt2))))
  (+ (nth 2 (cadr pt1)) (nth 2 (cdr (cadr pt2))))
Or
(setq x1 (nth 0 (cadr pt1)))
(setq y1 (nth 1 (cadr pt1)))
(setq z1 (nth 2 (cadr pt1)))
(setq x2 (nth 0 (cadr pt2)))
(setq y2 (nth 1 (cadr pt2)))
(setq z2 (nth 2 (cadr pt2)))
(list
  (+ x1 x2)
  (+ y1 y2)
  (+ z3 z3)
alanjt
  • Standby for witty remark...
Re: Which is better way?
« Reply #1 on: May 09, 2011, 10:32:05 AM »
(mapcar '+ pt1 pt2)
As far as your two go, if it's not needed to defined a variable, then I wouldn't, but it doesn't really hurt anything...as long as you ARE localizing your variables.  :wink:
Dropbox
« Reply #2 on: May 09, 2011, 10:58:45 AM »
What are the forms of pt1 and pt2?  Your two examples seem to contradict each other.
« Reply #3 on: May 09, 2011, 11:27:01 AM »
Yes, please give an example with numbers and not variables so we can see what you are trying to do. :-)
HasanCAD
« Reply #4 on: May 09, 2011, 12:10:36 PM »
gile
  • Marseille, France
« Reply #5 on: May 09, 2011, 12:33:18 PM »
As Alanjt said:
(cons 10 (mapcar '+ pt (cdr (assoc 10 ent))))
