Author Topic: 3d to 2d views engine  (Read 34581 times)
Re: 3d to 2d views engine
« Reply #75 on: January 30, 2008, 09:18:16 PM »
Great to see it coming along well again Mick !
« Reply #76 on: January 30, 2008, 09:25:15 PM »
Thanks Kerry, yes it is, I had to start from scratch but it's a lot better written this time (ie. safer and faster), things are 'clicking' fast so I better stay at it while the going's good :).
I will have a swag of 3d modeling tools coming out soon as well, stay tuned.
- John Carmack
- J.R.R. Tolkien
« Reply #77 on: January 30, 2008, 09:26:22 PM »
KOOL!
bikelink
« Reply #78 on: June 23, 2010, 11:06:12 AM »
I wrote a simple code that perform the projections of a solid in c#.
the result is very similar. the actual limit now it's understand what are the hidden lines.
i haven't time now to wrap the "Hlr Library" in c# but i think we can obtain a nice solution joining the c# and hrlapi
« Reply #79 on: June 23, 2010, 06:44:46 PM »
I've written a little wrapper to get some functionality from the hlr api but ideally it would need a fully blown wrapper to get the most out of it, my wrapper is more focused on what I need rather that exposing all it's functionality.
I'll find the code and post it if anyone's interested.
Mick.
- John Carmack
- J.R.R. Tolkien
bikelink
« Reply #80 on: June 24, 2010, 06:20:39 AM »
if You can post it we can  share it here and update it.  ;-)
« Reply #81 on: June 24, 2010, 06:37:54 PM »
No prob's, I'll dig up the code and post when I get some spare time.
- John Carmack
- J.R.R. Tolkien
bikelink
« Reply #82 on: June 29, 2010, 12:27:14 PM »
ok...while i'm waiting ...'cause  i'm eager to obtain my drawing
that's my result and i'm very happy...  I Wrote in c++ and then wrapped with a class in c#
Now I have a complete projections  (i can set colors, layers, lineid ecc..)   and of course.. my little lib ;)
« Reply #83 on: June 29, 2010, 04:52:17 PM »
Nice work!
The tricky bit is the transformations to put the views where you want them. I'll have some time later today and I'll post my wrapper code, cheers.
- John Carmack
- J.R.R. Tolkien
Jeff Benson
« Last Edit: October 04, 2012, 04:09:43 AM by Jeff Benson »
