Author Topic: Lastangle  (Read 2661 times)
Bryco
Lastangle
« on: December 09, 2007, 04:12:41 PM »
Where do you find this?
Glenn R
Re: Lastangle
« Reply #1 on: December 09, 2007, 04:59:58 PM »
Re: Lastangle
« Reply #2 on: December 09, 2007, 05:02:00 PM »
You mean the equivalent to --
(getvar "lastangle")
Bryco
Re: Lastangle
« Reply #3 on: December 09, 2007, 05:03:30 PM »
wasn't very descriptive i see now.
There is a setvar Lastpoint
and lastangle
Mp-yes
Glenn R
Re: Lastangle
« Reply #4 on: December 09, 2007, 05:09:09 PM »
Quick and nasty:
using System;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(BrycoLastAng.tcgsCommands))]
namespace BrycoLastAng {
/// <summary>
/// Summary description for tcgsCommands.
/// </summary>
public class tcgsCommands {
public tcgsCommands() {
// TODO: Add constructor logic here
// Define Command "AsdkCmd1"
[CommandMethod("BrycoLastAngle")]
static public void brycolastanglecommand() // This method can have any name
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
double lastAngle = (double)acadApp.GetSystemVariable("LASTANGLE");
ed.WriteMessage("\nValue of 'LASTANGLE' system variable: {0}", lastAngle);
Cheers,
Glenn in UK.
Bryco
Re: Lastangle
« Reply #5 on: December 09, 2007, 05:16:28 PM »
Thanks mate (damn you are quick)
I didn't know there was a GetSystemVariable.
I'm still plodding along with a polyline jig and as far as I can see acad uses this to start a polyarc when only one point has been picked
