Author Topic: How to change the Name of the Layout Tab ????  (Read 2838 times)
Krushert
  • FREE BEER Tomorrow!!
« on: October 11, 2007, 01:45:06 PM »
I can find a bunch of post about reading the name of the CTAB variable, but I can not find one on how to change the name via code.
Can someone point me in the right direction?
Thanks.
Krushert
Re: How to change the Name of the Layout Tab ????
« Reply #2 on: October 11, 2007, 04:04:20 PM »
Try here:
Thank you I will try to look at tomorrow.  Have to go home to a sick child.
KewlToyZ
« Reply #3 on: October 11, 2007, 04:10:07 PM »
Something like:
(defun c:MyLayout()
(command "expert" "2")
(setq shtnm (getstring "\nEnter new paper space layout description: (Example: 30x42-YourTitle) :"))
(command "layout" "t" "MyTemplate.dwt")
(command "MyLayoutTabName")
(command "layout" "rename" "MyLayoutTabName" shtnm)
(command "layout" "s" shtnm)
(princ "\nLayout renamed.")
Krushert
« Reply #4 on: October 12, 2007, 07:47:49 AM »
Something like:
(defun c:MyLayout()
Thank you KewlToyZ.
I suspected there would be a way to command line it, but I could not find it.
I will post back what I out together
KewlToyZ
« Reply #5 on: October 12, 2007, 12:01:42 PM »
Usually lisp will run through without the dialog box, but in case it pops up try "-layout" just in case.
DEVITG
« Reply #6 on: October 14, 2007, 09:57:45 AM »
A VL way
  (setq adoc
(vla-get-activedocument
   (vlax-get-acad-object)
(setq layout-col (vla-get-layouts adoc));_all layouts
(vlax-for layuot layout-col
  (print (vla-get-name layuot))
(setq old-layout-name "Layout2")
(setq new-layout-name "30x42-YourTitle")
(vla-put-name (vla-item   layout-col   old-layout-name ) new-layout-name)
KewlToyZ
« Reply #7 on: December 06, 2007, 08:44:35 PM »
Nice! Gonna have to ask if I can steal that bit of poetry :P
DEVITG
« Reply #8 on: December 06, 2007, 09:27:40 PM »
Beware nobody see you.
KewlToyZ
« Reply #9 on: December 06, 2007, 09:36:03 PM »
My posture leads me to beleive I am invisible  :ugly:
