Author Topic: Fatal Error exiting AutoCAD  (Read 3239 times)
ReneRam
« on: April 04, 2008, 01:45:47 PM »
Hi to everybody,
I have a strange error occuring in my program, it works fine unless I import ONLY blocks from an external drawing, in this case AutoCAD crashes when exiting.
Another strange thing about the issue is that if I import ther ents with the block I have no problem, or, if I terminate the execution of the code with a "me.close()" and save the drawing, I get the error, but when I re-open the drawing my blocks are there, but if I continue the execution of the program, I get no error, but the blocks magically disapear.
Sub Import_Blocks()
        ' Create the destination layer and set it as current
        '<< Here I call a sub that creats and sets the newly created Layer As Current >>
        ' Get Ents from Source Drawing into Current Drawing
        ' Loop Items in "lstBundlig" (this is a listbox in my form): the Source Layers with the ents to import
        ' THIS IS NOT relevant to the issue!!!
        For Each mySrcLay As Object In lstBundling.Items
            Dim SrcLayName As String = ""
            ' Get the Real Source LayerName
            For i As Integer = 0 To UBound(GTAMdrLays, 2)
                If mySrcLay = GTAMdrLays(1, i) Then
                    SrcLayName = GTAMdrLays(0, i)   ' the Source Layer Name
                    Exit For
                End If
            Next
            ' Get the DefaultEntity
            Dim DefaultEntity As String = ""
            For i As Integer = 0 To UBound(CartaMadre, 2)
                If mySrcLay = CartaMadre(3, i) Then
                    DefaultEntity = CartaMadre(10, i)   ' the DefaultEntity type
                    Exit For
                End If
            Next
            ' Import Layer with Ents
            WblockLayerIN(GtaBundleSource, SrcLayName)  ' this sub clones in all ents from the source drawing
            ' Update the WblockCloned objects: bring them in my destination layer
            Dim mySS As EditorInput.SelectionSet = SSLayer(SrcLayName)
            If Not IsNothing(mySS) Then
                Dim myDWG As ApplicationServices.Document = _
                        ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim myDB As DatabaseServices.Database = myDWG.Database
                Dim myTransMan = myDWG.TransactionManager
                Dim myTrans = myTransMan.StartTransaction
                Dim myEd As EditorInput.Editor = myDWG.Editor
                Dim myObjIds As DatabaseServices.ObjectIdCollection = _
                        New DatabaseServices.ObjectIdCollection(mySS.GetObjectIds)
                ' Loop ents in SelectionSet
                For Each myObjId As DatabaseServices.ObjectId In myObjIds
                    Dim myAcadEnt As DatabaseServices.Entity = myObjId.GetObject(OpenMode.ForRead)
                    ' Update Cloned Entity
                    ' Add Xrecord to the Cloned Entity
                    AddGTAXRecord(myAcadEnt, SrcLayName)
                    ' Modify entity to match destination Layer
                    With myAcadEnt
                        ' Move entity to the layer
                        .UpgradeOpen()
                        .Layer = lblBundle.Text
                        ' Update complex ents
                        If TypeOf myAcadEnt Is DatabaseServices.Hatch Then
                            Dim myHatch As DatabaseServices.Hatch = myAcadEnt
                            ' Update the Hatch
                        End If
                        .DowngradeOpen()
                        ' Check if the Entity must be cloned
                        Dim ClonedEnt As Boolean = False
                        Select Case myAcadEnt.GetType.Name
                            Case "Hatch"
                                If DefaultEntity = "isPattern" Then ClonedEnt = True
                            Case "Polyline", "Polyline2d", "Polyline3d"
                                If DefaultEntity = "isLType" Then ClonedEnt = True
                            Case "BlockReference"
                                If DefaultEntity = "isSimbol" Then ClonedEnt = True
                        End Select
                        If TypeOf myAcadEnt Is DatabaseServices.Hatch And Not ClonedEnt Then
                            ' User has hatches in a Polyline layer type.
                            ' Clone also the hatch
                        ElseIf Not ClonedEnt Then
                            ' entity must not be cloned: delete it from current drawing
                            .Erase()
                            .Dispose()
                        End If
                    End With ' End of Modify entity to match Bundle
                Next ' End of Loop ents in SelectionSet
                ' Commit and Dispose Transactions
                myTrans.Commit() : myTrans.Dispose() : myTransMan.Dispose()
                ' Update screen
                myEd.Regen()
            End If
            ' If I exit here, I have the blocks, but exiting AutoCAD I get the fatal error
            ' if I comment the following line of code, I don't get the error but I lose the blocks!
            Me.Close()
            ' Remove the source layer definition from tha LayerTable
            RemoveLayer(SrcLayName)
        Next ' End of Loop Items
    End Sub
Any help appreciated
Thanks in advance
René
ReneRam
Re: Fatal Error exiting AutoCAD
« Reply #1 on: April 07, 2008, 06:09:49 PM »
Wondering if I'm on the right track..., maybe some you guru's can tell me ...
digging in the ObjectArx documentation I found out that the blockreference is not as I thought, like when drawing, the block, but just the Block Definition plus some properties, so if my BlockDefinition has a "Circle", a "Rectangle" and an "AttributeDefinition", when I WblockClone the BlockReference in my drawing I'm not importing the the entities of each blockref.
May I must recreate (import) the BlockDef with the AttributeDef and then Insert them as a new BlockRef in the current drawing?
Still I don't understand why if I import the blockrefs with other ents (polys or hatches) everything works, but if I import only blockrefs
  • or the blocks disappear at the end of program execution after performing other activities
  • or Autocad gives the Fatal Error when exiting the drawing if I stop the program after the Commit and Dispose Transactions
Any advice is appreciated.
René
