Author Topic: Link between Text, Mtext and Attribute with Field  (Read 1662 times)
Fabricio28
« on: October 23, 2015, 06:16:40 AM »
Hi guys,
How are you?
I have to create a link with some informations.
So, I'm trying to create a Mtext as a field of attritubes.
i'd like to know if is possible to create that link between the objects to make faster my task. Because I have many objects in my project.
Regards
irneb
Re: Link between Text, Mtext and Attribute with Field
« Reply #1 on: October 23, 2015, 08:52:54 AM »
You'd need something to build the field codes and then place that into the MText. Effectively you'd want to get the Object ID and then the relevant property.
Something similar I did a while ago: http://www.cadtutor.net/forum/showthread.php?57342-Sum-Numbers-in-Mtext-Fields-to-Mtext-Field&p=389198&viewfull=1#post389198
Which was incorporated into my Caddons tools: http://sourceforge.net/p/caddons/code/HEAD/tree/Libraries/text.lsp
Used in the DimText command here (basically sums the values in several text entities into another - all you want to do is concatenate them, actually a bit simpler) : http://sourceforge.net/p/caddons/code/HEAD/tree/General/DimUtils.LSP
Fabricio28
« Reply #2 on: October 23, 2015, 11:02:29 AM »
Hi irneb,
Thank you for replay,
But I couldn't make that modification. I'm trying, but my knowledge is very limited.  :-(
Thank you
