Lisp to Create multiple viewport
(1/1)
francinez13:
I'm looking for a lisp to create multiple viewport.
I've found a lisp on this forum that almost meets my expectations, its name is NV.lsp. (see attached file)
I need 2 things, redo the same operation several times and insert the window not in the centre but in relation to a corner (for example the bottom left corner).
Does anyone know how to integrate this into this lisp?
Thank you very much in advance for the help
BIGAL:
Do you want make viewports at scale to match a title block in Layouts like in this image the red rectangs have been made matching a MVIEW at scale. This is a slect P/Line and walk along or by placing rectangs, Rotation is supported by twisting view in layout.
francinez13:
Yes, I need something like what you've drawn.
Do you have a Lisp so I can test it?
I also got an answer on the Autodesk forum, but I can only create one view after another. (see attached lisp). If possible it would be nice to select all View before inserting in the layout.
BIGAL:
Post a dwg with a title block in a layout and what scale you want the view at. The advanced version asks for title block to be used and scale. Retrieving the title block from a master layouts dwg.
Navigation
[0] Message Index
Go to full version
