Author Topic: Is active drawing new?[Solved]  (Read 1915 times)
shers
« on: June 27, 2015, 09:56:16 AM »
How can I check if the active drawing is new or empty?
« Last Edit: June 30, 2015, 01:32:37 PM by sresh »
Keith Brown
Re: Is active drawing new?
« Reply #1 on: June 27, 2015, 10:08:08 AM »
You can check the DBMOD and DWGTITLED system variables to see if the drawing has been named and/or needs saving.
DBMOD (System Variable)
Indicates the drawing modification status.
(Read-only)
Type:   Integer
Saved in:   Not-saved
Initial value:   0
The setting is stored as a bitcode using the sum of the following values:
1   Object database modified
4   Database variable modified
8   Window modified
16   View modified
32   Field modified
The DBMOD value is reset to 0 when you save the drawing.
DWGTITLED (System Variable)
Indicates whether the current drawing has been named.
(Read-only)
Type:   Integer
Saved in:   Not-saved
Initial value:   0
0   Drawing has not been named
1   Drawing has been named
shers
« Reply #2 on: June 30, 2015, 01:32:21 PM »
That worked! Thanks very much! :)
