Author Topic: 2007 - Copy & paste  (Read 14474 times)
VerticalMojo
2007 - Copy & paste
« on: April 28, 2006, 12:22:46 PM »
It works fine on 2007, but I save our dwgs as a 2000 dwg and when other people open them they seem to lose there ability to copy and paste... :?
VerticalMojo
Re: 2007 - Copy & paste
« Reply #1 on: April 28, 2006, 12:42:59 PM »
This is not cool, I will have to drop down back to 2000 if thats the case....
2007 is getting a low score from me!   :realmad:
M-dub
« Reply #2 on: April 28, 2006, 01:20:00 PM »
Something about that doesn't sound right.
I don't have 2007, so I can't prove or disprove what you're saying, but CTRL+C and CTRL+V is Windows functionality.  Is this problem occurring on multiple machines with 2000 loaded?  Have you tried Copy with Base Point, Paste As Block, Paste Special, etc.?
« Reply #3 on: April 28, 2006, 01:35:08 PM »
_pasteclip appears to be nonoperative in a translated document.
Copy works as expected
Yoland
« Reply #4 on: April 28, 2006, 01:38:50 PM »
But the question is if you configured your AutoCAD v.2007 to save how AutoCAD v.2004, doesn't work the Copy&Paste commands???
See: Menu Tools -> Options -> Tab Open and Save. Select "save as AutoCAD 2004/2004LT"
I don't know if I'm explain very well  :-(
Bye
Yolanda
VerticalMojo
« Reply #5 on: April 28, 2006, 02:38:53 PM »
It should still work if saved to 2004......
Is that what your asking Yolanda?
« Reply #6 on: April 29, 2006, 03:54:06 AM »
VM,
Have you tried a support Request ??
If so, What was the response. ?
If not, ...... perhaps you need to.
« Reply #7 on: April 29, 2006, 03:55:25 AM »
... and ditto with the other issues you are having.
Dent Cermak
« Reply #8 on: April 29, 2006, 02:25:07 PM »
WoW!! A shortcut to having Laurie Comerfort yell at you to "DO THE TUTORIALS!!". Man!! Just what I always wanted!  ^-^
nivuahc
« Reply #9 on: April 29, 2006, 04:37:49 PM »
:lmao:
hyposmurf
« Reply #10 on: April 29, 2006, 09:44:01 PM »
I know an number of 2007 LT users get a pop up alert with an ARX problem,doenst go until theyve clicked it for about 3mins.This happens every time they paste something.Quite frustrating.Maybe something ishnt quite right with the copy paste function in 2007, hard to beleive though itd get that far without it being noticed.
VerticalMojo
« Reply #11 on: May 01, 2006, 11:48:45 AM »
I am unable to send a support Request because of the limited access to the Internet that I have here. I will bring it up with upper management, and hopefully I will be able to soon.
hyposmurf
« Reply #12 on: May 01, 2006, 03:18:00 PM »
I can understand you fruistration I almost had 2007 removed from my machine and replaced with 2006.Im going to try and ride the wave of problems with the software for a bit longer and see what can be done about them.
hudster
« Reply #13 on: May 03, 2006, 07:59:19 AM »
We have the same problems here. no copy and paste for lower users, mine works though :-D
VerticalMojo
« Reply #14 on: May 03, 2006, 09:19:25 AM »
Can someone request some support on this? I am unable to and would like to see a solution to this...... This is a big problem here at the office!
