Code Red => AutoLISP (Vanilla / Visual) => Topic started by: HasanCAD on January 18, 2024, 04:13:55 AM
I am wondering the lisp is working in most of files and not working in few numbers of files.
error
Lee lisp
http://lee-mac.com/fieldobjects.html
The cad file attached.
Thanks for your help
HasanCAD,
It is working, but you just need to zoom out really far to see it (see attached image 'DifferentAreas').
This is happening because you are using a custom UCS that the program its not accounting for.
If you run the "UCS" command, then select the "World" option to reset the UCS, then it will appear correctly (see attached image 'AfterUCSReset')
Thanks CodeDing
Working good
