Author Topic: reading object data  (Read 4588 times)
drizzt
reading object data
« on: October 04, 2006, 01:33:23 PM »
I recieved a file from a client. He converted it from 2007 to 2000 for me. What I need to know, is if there was object data attached, did I loose it in the conversion? If not, how do I read it. It is a file that has well locations and the data that is supposed to be attached is the owner and lat / long of the well.
Thanks in advance for your help
drizzt
Re: reading object data
« Reply #1 on: October 04, 2006, 01:58:35 PM »
PS
is there a way to extract that data into a table format?
David Hall
  • Automatic Duh Generator
« Reply #2 on: October 04, 2006, 05:57:08 PM »
I think you need map or ldd to read object data
drizzt
« Reply #3 on: October 04, 2006, 06:03:36 PM »
I do have LDD2000. But not sure if the conversion from LDT07 to LDD2000 lost the data, or I just don't know how to read the data.
David Hall
« Reply #4 on: October 04, 2006, 06:13:16 PM »
Its been a long time since ive used it, but i remember Map->Tools->ObjectData-> Something that would let you see it
Dinosaur
« Reply #5 on: October 04, 2006, 07:14:57 PM »
There is also an option when exporting whether or not to export the MAP data with the drawing.  Unless this option was chosen, you got no data.  I would not be surprised if the data was unable to survived the trip back to 2000 regardless.
drizzt
« Reply #6 on: October 05, 2006, 09:50:43 AM »
ok I tried the map / tools / convert object data to database links. But I can't define the link template. I get the message ASE error: 45057 - error: OLEDB provider is not registered.
Does this mean that the data was lost
Dinosaur
« Reply #7 on: October 05, 2006, 10:07:11 AM »
The data may be there but your 2000 version doesn't know what to do with it.  The data format may have changed since 2000 or it may be a in a format not yet available 2000.  Is 2000 the latest LDT/MAP you have access to?
drizzt
« Reply #8 on: October 05, 2006, 10:10:31 AM »
unfortunaltley, yes.
Dinosaur
« Reply #9 on: October 05, 2006, 10:36:33 AM »
If you can you post the file or send it to me I will try to extract the data.
drizzt
« Reply #10 on: October 05, 2006, 11:57:34 AM »
I have attached the file. I appreciate your help Din0
Dinosaur
« Reply #11 on: October 05, 2006, 12:14:54 PM »
For some reason, I can not download the file.  Either try again or email it to me at the address in my profile.
Dinosaur
« Reply #12 on: October 05, 2006, 03:44:22 PM »
I have just sent drizzt an ESRI shape file that contains all of the attached data, but I am not sure what r2000 can do with it.  If anyone with experience doing this in r2000 has any suggestions please jump in and help.
mohobrien
« Reply #13 on: October 19, 2006, 04:02:55 PM »
Did this get sorted out?
Dinosaur
« Reply #14 on: October 19, 2006, 11:29:37 PM »
drizzt indicated in his last email that if all else failed, he had a GIS reader that would allow him to view the data.  I never heard if he could import the data into 2000, but I think it should have worked for him.  I hope so as the file he had was full of wonderful data waiting to be mined.
« Reply #15 on: October 23, 2006, 12:38:44 PM »
The 'best' way to deal with Object data, or any SOURCE file.
Open a blank MAP session (or Civil 3d) attach the SOURCE file:WELLS-WATER-r2000.dwg
Perform an ALL query, using ALTER properties and define your text properties
from the attached object data.
Otherwise,open the file, and use MAP>>Object Data>>Edit Object data to view the attached object data
OR,
Use MAP>>Annotation>>Define Annotation Template and create Annotation Templates to label the
various features as desired from the attached object data.
