Author Topic: Cycle Dimensioning Problem  (Read 2060 times)
myloveflyer
« on: July 12, 2010, 11:47:02 PM »
Please friends, help, How to write to achieve the figure marked effect?
(defun c:test(/ H L pt1 pt2 pt3 pt4)
(setq H (getreal "\n Hight is:"))
(setq L (getreal "\n Length is:"))
(setq pt1 (getpoint "\n Insertion point:"))
(setq pt2 (polar pt1 0.0 4000))
(setq pt3 (polar pt2 (* pi 1.50) H))
(setq pt4 (polar pt1 (* pi 1.50) H))
(command "line" pt1 pt4 "")
(command "line" pt2 pt3 "")
(command "_.copy" (entlast) "" "m" pt2)
(repeat (fix 4.0 )
(command (setq pt2 (polar pt2 0.0 L)))
(command "")
(command "dimlinear" pt1 pt2 "h" "@2000,2000")
Never give up !
Tharwat
  • Hypersensitive
Re: Cycle Dimensioning Problem
« Reply #1 on: July 13, 2010, 09:58:17 AM »
Here is another program that might suite your needs .
Try it ....
(defun c:test (/ L H G pt1 pt2 pt3)
  (setq L (getint "\nSpecify Length of Line:")
G (getint "\nSpecify Gap between Lines:")
arr (getint "\nNumber of Lines:")
pt1 (getpoint "\nSpecify first point:")
pt2 (polar pt1 (+ (/ pi 2) pi) L)
pt3 (list(car pt1)(+ (cadr pt1)150))
  (vl-cmdf "_.line" pt1 pt2 "")
  (setq Lst (entlast))
  (vl-cmdf "_.-array" Lst "" "_r" "" arr G)
  (vl-cmdf "dimlinear" pt1 (list (+ (car pt1)G)(cadr pt1)) pt3)
Regards
Tharwat
« Reply #2 on: July 13, 2010, 06:34:05 PM »
Here is an old routine that may give you some ideas.
It uses an existing line to offset but can be modified.
Fact is I use it to array many different objects.
;;; TrussOffset.lsp
;;; Author: Copyright© 2005 Charles Alan Butler
;;; Version:  1.0 May. 23, 2004
;;; Version:  1.1 Jul. 22, 2004
;;; Purpose: offset objects user offset distance to fill selected area
;;;          Only works on X & Y directions.
;;;          Will work with any objects
;;; [Prompts]
;;; Select objects
;;; Enter or select offset distance
;;; Pick start & end point of array distance, these picks only establish
;;;  direction and total distance, not start & end points.
(defun c:trusso (/ *error* p1 p2 ss dist num tmp)
  ;;; error function & Routine Exit
(defun *error* (msg)
    (not
      (member
        msg
        '("console break" "Function cancelled" "quit / exit abort" "")
  ) ; if
  (setvar "osmode" useros)
  (setvar "CMDECHO" usercmd)
 ;end error function
  (setvar "CMDECHO" 0)
  (setq useros (getvar "osmode"))
  (setvar "orthomode" 1)
  (prompt "\nSelect objects to offset")
  (setq ss (ssget))
  (if ss
      (if (null to_step); global var
        (setq to_step 24)
        (setq to_step (abs to_step))
      (setq tmp (getdist (strcat "\nEnter or pick offset amount. <"(rtos to_step) "> ")))
      (if tmp
        (setq to_step tmp)
      (setq p1 (getpoint "Pick Starting point"))
      (if p1
          (setq p2 (getpoint p1 "Pick End point"))
          (if p2
              (setq p1 (list (car p1)(cadr p1)) ;3d to 2d
                    p2 (list (car p2)(cadr p2))
                    dist (distance p1 p2)
                    num  (fix (1+(/ dist to_step)))
                    ang  (angle p1 p2)
              (if (or (equal ang pi 0.2)
                      (equal ang (* pi 1.5) 0.2)
                (setq to_step (- to_step)); reverse the direction
              (setvar "osmode" 0)
                ((or (equal ang 0 0.2) ; Horrizontal
                     (equal ang pi 0.2)
                 (command "_.array" ss "" "R" "" num to_step)
                ((or (equal ang (/ pi 2) 0.2) ; Vertical
                 (command "_.array" ss "" "R" num "" to_step)
              ) ; end cond stmt
            ) ; end progn
          ) ; endif
        ) ; end progn
      ) ; endif
    ) ; end progn
  ) ; endif
;;;==========  Exit Sequence  ============
  (*ERROR* "")
  (princ); Exit quietly
) ; end defun
(prompt "\nOffset Object Loaded. Enter OOS to run.")
myloveflyer
« Reply #3 on: July 14, 2010, 12:57:46 AM »
Very grateful to my friends, I might have a problem statement, copy the object or array of objects to achieve the objective, the key is how to do a continuous mark? :cry:
Tharwat's procedures failed to achieve continuous labeling, CAB program is very good, is not a continuous mark.
Thanks !
Never give up !
