Author Topic: Preferences Object Reactor?  (Read 3361 times)
BlackBox
« on: June 05, 2012, 12:30:23 PM »
Silly question, but which reactor type (and event) is used to fire a callback when a Preferences Object is modified?
I'm attempting to programmatically determine when the Preferences Object (or a property of) has been changed, without catching all Options Command invocations, and monitoring each LispWillStart events, as either may make changes.
Re: Preferences Object Reactor?
« Reply #1 on: June 05, 2012, 01:01:28 PM »
Since many of the properties of the Preferences Object are stored by Env Vars in the Registry or Sys Vars, you would need a way to monitor the values of such variables (vlr-sysvar-reactor immediately springs to mind for the System Variables), not sure how you would monitor the registry however.
BlackBox
« Reply #2 on: June 05, 2012, 01:27:58 PM »
Thanks for the response, Lee.
Unfortunately, there is no System Variable for the property I am attempting to monitor.
Frankly, I am shocked that there's no direct way of monitoring Visual LISP Objects (in general).   :-o
I really wanted to do this project in LISP (put in a fair amount of my personal time), but it looks as though I may have to start over with .NET  :| ... Good practice I guess. LoL
jbuzbee
« Reply #3 on: June 06, 2012, 12:24:08 PM »
What specifically are you wanting to track?
James Buzbee
Windows 8
BlackBox
« Reply #4 on: June 06, 2012, 12:38:56 PM »
Any of the Preference Property Objects, i.e., Display, Drafting, Files, Profiles, Selection, etc.
Specifically, any Preferences Property Object properties that do not have System Variables assigned.
irneb
« Reply #5 on: June 06, 2012, 01:40:37 PM »
Actually I'm unaware of something to monitor those even in ObjectARX, so I'm guessing the same applies for Acad's DotNet libraries.
You might have to monitor the registry keys themselves. I know you get programs which can do this, so it must be possible. Actually, here's a sample C#
http://stackoverflow.com/questions/826971/registry-watcher-c-sharp
BlackBox
« Reply #6 on: June 06, 2012, 01:49:07 PM »
Thanks Irneb, WqlEventQuery sounds like what I'm after.
... Started [re-]coding the application in C# last night, I only finished the CommandMethod user prompt, and conditional structure (based upon the user's PromptResult). Next, I need to code some app-specific registry classes, so this seems to fit right in with the application structure I'm envisioning. :-D
Cheers!
** Edit - Oh, now I 'spose that I need to find the registry keys to monitor, too. lmao
« Reply #7 on: June 06, 2012, 01:52:48 PM »
A suggestion for the Visual LISP route: how about using a Command Reactor with a call-back function triggered on the :vlr-commandwillstart event to record the necessary registry keys when the 'Options' command is used; then, another call-back function triggered on the :vlr-commandended event that will check those same keys against the cached values to detect any changes.
Just an idea | Untested.
irneb
« Reply #8 on: June 06, 2012, 02:08:04 PM »
That's also a nice idea Lee! Though it's still going to make RM's day searching for all the envars and/or registry keys  :lmao:
BlackBox
« Reply #9 on: June 06, 2012, 02:10:30 PM »
That is almost the exact methodology that I have been using prior to posting this thread.
The problem being, as I see it, that it's inefficient in that it monitors all instances of the user issuing the OPTIONS command, _and_ either has to monitor all LispWillStart events, or knowingly leave open a back door (by not doing so), as LISP can also change these Properties.
That can be done, but it seems like overkill for what I see as such a small, yet intuitive task.
Actually, if I go with the pure Reactor route, it's easier to programmatically Set the appropriate values upon *WillStart events, than teaching myself how to _properly_ use Delegates, and Event Monitors. LoL It's just unnecessary burden on the end-user's processing time. LoL
I appreciate everyone's assistance!
jbuzbee
« Reply #10 on: June 07, 2012, 09:10:09 AM »
All that and more . . ..
Yea, you will have to hard code the specific registry entrees your interested in.
good luck - sorry I couldn't have been more help . . ..
James Buzbee
Windows 8
BlackBox
« Reply #11 on: June 07, 2012, 10:42:26 AM »
No worries; cheers!
