Author Topic: Exploding Mleaders  (Read 2457 times)
cmwade77
Exploding Mleaders
« on: August 22, 2011, 12:56:37 PM »
For part of a routine that I am working on, I need to temporarily explode mleaders, I have tried both of the following:
(setq SS (ssget "_X" (list (cons 0 "MULTILEADER"))))
(SS
(while (setq Ent (ssname SS 0))
(setq Obj (vlax-ename->vla-object Ent))
(vla-explode Obj)
(ssdel (ssname SS 0) SS)
(SS
(command "._explode" SS "")
Neither one seems to work correctly, especially with mleaders with blocks attached to them, any ideas?
Re: Exploding Mleaders
« Reply #1 on: August 22, 2011, 01:00:13 PM »
MLEADERS don't have an explode method. Why do you need to explode them? Perhaps there is a better route.
cmwade77
« Reply #2 on: August 22, 2011, 01:03:14 PM »
What is annoying is I can manually explode them, but using LISP, it comes up nil when I try to explode them.
Basically, I have everything setup to use Data Extraction, but since it does not support mleaders, I have to explode them first, then undo the exploding.
cmwade77
« Reply #3 on: August 22, 2011, 01:47:40 PM »
Nevermind, once again LeeMac and AlanJT have already solved my problem, this time it was posted at CADTutor....http://www.cadtutor.net/forum/showthread.php?49219-lisp-to-explode-all-mleaders&p=335641&viewfull=1#post335641
How do they ever have time to get actual work done with all that they contribute? It amazes me.
alanjt
  • Standby for witty remark...
« Reply #4 on: August 22, 2011, 01:55:24 PM »
Yeah, it's call not exploding them.  :-P
Dropbox
« Reply #5 on: August 22, 2011, 04:12:57 PM »
Well DUH  :-P  :-)
cmwade77
« Reply #6 on: August 22, 2011, 05:02:39 PM »
Well DUH  :-P  :-)
Yeah, like I said, it is a very temporary explosion, here is my code for those that are interested:
(defun c:Count (/ *ACAD_DOC* SS PT DWG_Folder)
(setq *ACAD_DOC* (vla-get-ActiveDocument (vlax-get-acad-object)))
;Supporting Functions
(defun count_MLExp2 (/ *error* ss vl ov); Code from AlanJT's adaptation of LeeMac's Code, posted at http://www.cadtutor.net/forum/showthread.php?49219-lisp-to-explode-all-mleaders&p=335641&viewfull=1#post335641
  (defun *error* (msg)
(and ov (mapcar 'setvar vl ov))
(or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **"))
  (setq vl '("CTAB" "CMDECHO" "QAFLAGS")
ov (mapcar 'getvar vl)
  (mapcar 'setvar (cdr vl) '(0 5))
  (foreach x (cons "Model" (layoutlist))
(if (setq ss (ssget "_X" (list '(0 . "MULTILEADER") (cons 410 x))))
  (progn (setvar 'ctab x) (command "_.explode" ss ""))
;End of Supporting Functions
(vla-startundomark *ACAD_DOC*)
(setq PT (getpoint "\nSelect point for table: "))
(command "._-layer" "_thaw" "*" "_on" "*" "_unlock" "*" "")
(count_MLExp2)
(setq DWG_FOLDER (strcase (getvar "DwgPrefix")))
(vl-cmdf "._-dataextraction" "H:\\0ACAD Support\\AutoCAD\\Customization\\Breen.DXE" PT)
(vl-cmdf "._-wblock" (strcat DWG_Folder "DXE_TEMP.dwg") "" "0,0" (entlast) "")
(vla-endundomark *ACAD_DOC*)
(command "._undo" "1")
(vl-cmdf "._-insert" (strcat "*" DWG_Folder "DXE_TEMP.dwg") "0,0" "1" "0")
(vl-file-delete (strcat DWG_Folder "DXE_TEMP.dwg"))
You would need to setup your own Data Extraction template based on your needs, but it works well, can count anything you need it to, blocks or otherwise, including within Dynamic Arrays.
