Author Topic: Extract Title Block Attributes  (Read 2806 times)
cadpro
« on: November 03, 2011, 10:47:18 AM »
How do I extract one of the title block's attribute from a drawing with many layouts? That is, even if there are many layouts for a drawing, I only need info from any one of the title blocks, probably the first layout. Can this be achieved please?
Re: Extract Title Block Attributes
« Reply #1 on: November 03, 2011, 11:07:27 AM »
Just go to straight to the definition(BlockTableRecord) and use BlockTableRecord.GetBlockReferenceIds() to grab a reference and get the attribute.
cadpro
« Reply #2 on: November 03, 2011, 03:59:29 PM »
Thanks Jeff! That did the job.
cadpro
« Reply #3 on: November 03, 2011, 05:47:02 PM »
Sorry Jeff. I couldn't get it to work. I could only get the tags. The TextStrings return empty. This is my code.
public void GetTitleAtts()
            Database db = doc.Database;
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt["A1"], OpenMode.ForRead);
                StringCollection colNames = new StringCollection();
                foreach (ObjectId adId in btr)
                    DBObject adObj = tr.GetObject(adId, OpenMode.ForRead);
                    AttributeDefinition ad = adObj as AttributeDefinition;
                    if (ad != null)
                        colNames.Add(ad.Tag);
                tr.Commit();
« Reply #4 on: November 03, 2011, 05:53:54 PM »
This was not thought out well and thrown together quickly but,
 I mainly converted this to VB to see how indexer methods were done and if atts[""]; instead of atts.get_Item("");  from C# could be used.
        <CommandMethod("TitleBlock")> _
        Public Sub TitleBlock()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim block As BlockTableRecord = trx.GetObject(bt("TitleBlock"), OpenMode.ForRead)
                Dim atts As New AttributedTextInfo(block.GetBlockReferenceIds(True, False).Item(0))
                Application.ShowAlertDialog(atts("TagValue"))
                trx.Commit()
            End Using
Had to use <DefaultMember("Item")>  attribute & Default Public ReadOnly Property
Imports System.Reflection
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
<DefaultMember("Item")> _
Public Class AttributedTextInfo
    Implements IEnumerable
    Private _objectId As ObjectId
    Private _attributes As Dictionary(Of String, String)
    Public Sub New(brefId As ObjectId)
        _objectId = brefId
        _attributes = New Dictionary(Of String, String)()
        getAttributes()
    Private Sub getAttributes()
        Using trx As Transaction = _objectId.Database.TransactionManager.StartTransaction()
            Dim blockRef As BlockReference = trx.GetObject(_objectId, OpenMode.ForRead)
            If blockRef IsNot Nothing Then
                For Each id As ObjectId In blockRef.AttributeCollection
                    If id.ObjectClass = RXClass.GetClass(GetType(AttributeReference)) Then
                        Dim attRef As AttributeReference = trx.GetObject(id, OpenMode.ForRead)
                        _attributes.Add(attRef.Tag, attRef.TextString)
                    End If
                Next
            End If
            trx.Commit()
        End Using
    Default Public ReadOnly Property Item(tag As String) As String
        Get
            Return _attributes(tag.ToUpper())
        End Get
    End Property
    Public Function GetEnumerator() As System.Collections.IEnumerator Implements System.Collections.IEnumerable.GetEnumerator
        Return _attributes.GetEnumerator()
    End Function
End Class
« Reply #5 on: November 03, 2011, 06:05:24 PM »
That is because you are looking in the definition and the textString is equal to what was entered for default(TextString = Default)
Just grab the first reference if is does not matter and use AttributeReference
         [CommandMethod("GetTitleAtts")]
                BlockReference bref = (BlockReference)tr.GetObject(btr.GetBlockReferenceIds(true, false)[0], OpenMode.ForRead);
                foreach (ObjectId adId in bref.AttributeCollection)
                    AttributeReference ad = adObj as AttributeReference;
                    if (ad != null)
                        colNames.Add(ad.TextString);
                tr.Commit();
                foreach (string s in colNames)
                    Application.ShowAlertDialog(s);
kaefer
« Reply #6 on: November 04, 2011, 03:12:13 AM »
Hi Jeff,
that's all very well what you're demonstrating there. Just let me remark that from a software design perspective it's a not so great idea to implement IEnumerable with an indexer, because IEnumerable is both lazy and potentially infinite. It makes sense only as far as it's a light-weight interface compared to ICollection or IDictionary, and since you're using a Dictionary under the hood, then why don't you go the whole way?
The standard approach when working with sequences would be using FirstOrDefault<TSource> (Seq.tryFind in F#) to return the first element that satisfies a given predicate, or default(TSource) when none is found.
Cheers, Thorsten
gile
  • Marseille, France
« Reply #7 on: November 04, 2011, 04:26:49 AM »
I had to build a similar class, here's the way I did it (I only add an Indexor and a Constructor from ObjectId I didn't needed when I wrote this).
I needed a class implementing IEqualityComparer too, so that the Linq GroupBy() extension method can be used with a 'BlockAttribute' collection.
    public class BlockAttribute
        private string _name;
        private Dictionary<string, string> _atts;
        public string Name
            get { return _name; }
        public Dictionary<string, string> Attributes
            get { return _atts; }
        public string this[string key]
            get { return _atts[key.ToUpper()]; }
        public BlockAttribute(BlockReference br)
            SetProperties(br);
        public BlockAttribute(ObjectId id)
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                SetProperties(tr.GetObject(id, OpenMode.ForRead) as BlockReference);
        new public string ToString()
            if (_atts != null && _atts.Count > 0)
                return string.Format("{0}: {1}",
                    _name,
                    _atts.Select(a => string.Format("{0}={1}", a.Key, a.Value))
                        .Aggregate((a, b) => string.Format("{0}; {1}", a, b)));
            return _name;
        private void SetProperties(BlockReference br)
            if (br == null) return;
            _name = br.IsDynamicBlock ?
                ((BlockTableRecord)br.DynamicBlockTableRecord.GetObject(OpenMode.ForRead)).Name :
                br.Name;
            _atts = new Dictionary<string, string>();
            foreach (ObjectId id in br.AttributeCollection)
                AttributeReference att = (AttributeReference)id.GetObject(OpenMode.ForRead);
                _atts.Add(att.Tag.ToUpper(), att.TextString);
    public class BlockAttributeEqualityComparer : IEqualityComparer<BlockAttribute>
        public bool Equals(BlockAttribute x, BlockAttribute y)
            if (!x.Name.Equals(y.Name, StringComparison.CurrentCultureIgnoreCase)) return false;
            foreach (KeyValuePair<string, string> att in x.Attributes)
                if (!y.Attributes.ContainsKey(att.Key)) return false;
                if (!y.Attributes[att.Key].Equals(att.Value)) return false;
            return true;
        public int GetHashCode(BlockAttribute obj)
            return base.GetHashCode();
« Last Edit: November 04, 2011, 07:50:53 AM by gile »
« Reply #8 on: November 04, 2011, 12:10:41 PM »
Hi Jeff,
Cheers, Thorsten
Thanks for pointing that out.
