Author Topic: Ask for help to find point by VLisp  (Read 2391 times)
bdycad
« on: June 22, 2006, 03:38:52 AM »
Help me .
hendie
Re: Ask for help to find point by VLisp
« Reply #1 on: June 22, 2006, 03:47:53 AM »
a bit more information would probably help others in trying to assist you.
by what criteria are you trying to find that "point" ~ is it the centre of the largest area ?, any arbitrary point in the largest area ?, the intersection point of all the corners of the largest area ? or...
the more information you can give, the easier it is for people to help
bdycad
« Reply #2 on: June 22, 2006, 04:06:30 AM »
Like this .
« Reply #3 on: June 22, 2006, 04:09:33 AM »
How many do you have to do ?
Do you need a complete programatic solution, or mixed manual and software ?
bdycad
« Reply #4 on: June 22, 2006, 04:28:43 AM »
After finding this point, I want to write the area or other massage there.
« Reply #5 on: June 22, 2006, 04:49:51 AM »
it took me less than a minute to do it by hand ...
how do you currently do it ?
Want some help with a manual method ?
« Reply #6 on: June 22, 2006, 08:56:52 AM »
This is what I would do:
Pick three points, start, any where in the pline to use then the end.
That would get the vertex to use & a cut off point, thus creating a new pline.
Then get the centroid of that pline.
But the centroid is not the point you are looking for or is it?
