Author Topic: Video Problem with one Drawing  (Read 5030 times)
Rob...
Re: Video Problem with one Drawing
« Reply #15 on: January 29, 2015, 02:30:24 PM »
Audit in ACAD2006 found no errors and that command is not in 2006.
I run into this a lot because I am using MEP. I think you need to EXPORTTOAUTOCAD in order to get rid of that stuff. It's libraries and dictionaries for AEC content. It doesn't look like you are using any and I thought it might help with performance. Just a shot in the dark on my part, but your saving back as a DXF did the same thing plus more.
Did you by chance try WBlocking the drawing before the resorting to DXF?
CAD Tech
« Reply #16 on: January 29, 2015, 02:38:00 PM »
I did delete all the arrow hatches (ANSI 31) and saved to a new DWG name.
So far no crashes. maybe the viewports are not the problem.
I will try a solid hatch now.
Bethrine
« Reply #17 on: January 29, 2015, 02:41:32 PM »
FYI: My current video card: NVIDIA Quatro K5000
http://www.nvidia.com/object/quadro-k5000.html
 :wideeyed2: :wideeyed:
« Reply #18 on: January 29, 2015, 03:24:33 PM »
Just tested it on a computer here that has a Radeon 4550. It does not lock up, but you should definitely upgrade your video card :)
Rob...
CAD Tech
« Reply #21 on: January 29, 2015, 04:36:32 PM »
Take a closer look: I'm looking at 512GB :)
SAMSUNG 850 Pro Series MZ-7KE128BW 2.5" 128GB SATA III 3-D Vertical Internal Solid State Drive
« Reply #22 on: January 29, 2015, 07:23:52 PM »
FWIW .. you'll get much more bang for your buck with the EVO series over PRO. I have 8 of them (250GB) in our office and they're rock solid.
Bethrine
« Reply #23 on: January 30, 2015, 09:00:30 AM »
Okay. You guys lost me...aren't an SSD and a graphics card two seperate animals? SSD is "storage" right? and graphics card is, well, graphics? Or does an SSD do stuff I am unaware of?  :?
« Reply #24 on: January 30, 2015, 09:05:38 AM »
Right you are but I don't have money for both. :(
So if I can live with the Video Card I will spend the money on the SSD.
Ron, given that the Pro is slightly faster & 5 year warranty you still think EVO is a better buy?
Bethrine
« Reply #25 on: January 30, 2015, 09:10:38 AM »
Ah, Okay. Thank you.  :-) and that sucks.
« Reply #26 on: January 30, 2015, 09:15:59 AM »
Comparison of the smaller drives: I expect the 512GB to be similar to 256GB in speed
http://ssd.userbenchmark.com/Compare/Samsung-850-Pro-256GB-vs-Samsung-840-Evo-250GB/2385vs1594
Problem is my computer has a SATA II and will not be at max speed.
« Reply #27 on: January 30, 2015, 10:17:23 AM »
It's $100 cheaper .. I'd say it's worth it. Real world application you won't notice a difference between the two. Now you need a sata 3  computer :)
« Reply #28 on: January 30, 2015, 12:03:14 PM »
Wow, you're spending my money faster than I can make it.
Kidding aside, it may be time for a new box so I can upgrade the video card & get SSD.
Only problem is it's not broke.  ;)
