Author Topic: Video Problem with one Drawing  (Read 5028 times)
« on: January 29, 2015, 12:24:22 PM »
Not sure what is going on with this DWG. Using ACAD2006
There are a lot of hatches & may be the cause.
When I pan & zoom in model space the display of model space gets corrupted, turns black (background color) and if I cursor over an object it becomes visible.
But then ACAD locks up & I have to kill the acad process.
I tried deleting the hatches but no luck.
Any ideas?  No other drawing so far are giving me trouble.
Rob...
Re: Video Problem with one Drawing
« Reply #1 on: January 29, 2015, 12:36:08 PM »
No issues here. It's probably not the file.
Do you have hardware acceleration on?
CAD Tech
« Reply #2 on: January 29, 2015, 12:36:52 PM »
what are your adaptive degradation settings?
« Reply #3 on: January 29, 2015, 12:46:18 PM »
Here is my dialog.
Bethrine
« Reply #4 on: January 29, 2015, 12:46:53 PM »
I had a very similar issue, along with multiple copies of the pointer crosshairs that wouldn't erase, etc. They upgraded my graphics card and it fixed it here.
---> googling "adaptive degradation" (My AutoCAD book went with my previous boss  :cry:  and I haven't gotten a new one yet.)
« Reply #5 on: January 29, 2015, 12:49:34 PM »
No problems here either.
« Reply #6 on: January 29, 2015, 12:54:04 PM »
no issues here....perhaps you should enable your hardware?
« Reply #7 on: January 29, 2015, 12:54:31 PM »
Thanks for testing.
My video driver is up to date although this card is not the best for ACAD
« Reply #8 on: January 29, 2015, 12:56:31 PM »
Won't use Hardware Acceleration.
Rob...
« Reply #9 on: January 29, 2015, 12:59:45 PM »
Uh oh, it may be time to upgrade that video card.
CAD Tech
« Reply #10 on: January 29, 2015, 01:04:09 PM »
never liked AMD cards....NEVER
Rob...
« Reply #11 on: January 29, 2015, 01:08:07 PM »
At home, I've never bought anything but AMD and NEVER had a problem.
CAD Tech
« Reply #12 on: January 29, 2015, 01:12:58 PM »
All other drawings are fine (I hope) so there is something different about this one.
Rob...
« Reply #13 on: January 29, 2015, 01:21:15 PM »
AUDIT?
AECOBJEXPLODE found and erased a lot.
CAD Tech
« Reply #14 on: January 29, 2015, 02:24:14 PM »
Audit in ACAD2006 found no errors and that command is not in 2006. But all the viewports were originally on layer "Defpoints".
I recently moved them to a Hidden layer.
OK I saved back to R12 dxf & lost the layouts but no video problem.
Perhaps it is the dreaded Defpoints gremlin.  >:D
