CAB/Keith, <--<< you mean Kerry not Keith
Should I cut/paste CAB updated code to the the img_menu.lsp? NO NO NO
Is defun the command for a lsp? it defines a function
In ACAD type VLIDE then click on help, click the INDEX tab, enter defun to see the help info.
(defun mocorosc, therefore type mocorosc to run that lisp? Well not exactly:
If the function is named (defun MyRoutine at the command line in acad you would type (MyRoutine)
If the function is named (defun c:MyRoutine at the command line in acad you would type MyRoutine
If the function is expecting arguments like (defun MyRoutine (arg1 arg2 / local vars) you
would have to supply the arg1 ans arg2
Is it poss to have several libraries/categories with your program? Yes, but I don't have the time
right now to walk you through it. My work load won't permit it. Perhaps someone else will help you
through the process, although this is a little complex for your first lisp project.
