Author Topic: How to stop while loop?  (Read 2678 times)
HasanCAD
« on: October 09, 2013, 07:02:46 AM »
I coaded this lisp but cant stop while loop.
Please help
(defun c:ctxt ( / _value data txt1 txtn )
  (setq data " ")
  (defun _value (str / ATTr)
    (while
      (not
(if (and (setq ATTr (car (nentsel str)))
(member (vla-get-objectname (setq ATTr (vlax-ename->vla-object ATTr))) '("AcDbAttribute" "AcDbText")))
  ATTr
  (progn (princ str) nil)))) ATTr)
  (if (setq txt1 (vla-get-textstring (_value "\nSelect First attribute/Text : ")))
      (while
(setq txtn (vla-get-textstring (_value "\nSelect Next attribute/Text : ")))
(setq data (strcat data " + " txtn)))
      (setq data (strcat txt1 data ))))
  (setq ip (getpoint "\nPick Text insertion point"))
   (entmakex (list (cons 0 "TEXT")
                  (cons 10  ip)
                  (cons 40 (getvar "textsize"))
                  (cons 1  data)))
(princ " Type   CTXT    to invoke the lisp")
Re: How to stop while loop?
« Reply #1 on: October 09, 2013, 08:52:05 AM »
I think I would do the routine like this: (quickly done)
  1. (defun c:ctxt ( / done ent ip string1 string2)
  2.
  3.   (defun _getString (ent / obj subent)
  4.     (setq obj (vlax-ename->vla-object (car ent)))
  5.     (cond
  6.       ((vlax-property-available-p obj 'textstring) (vla-get-textstring obj))
  7.       ((null (setq subent (nentselp (cadr ent)))) nil)
  8.       ((and subent
  9.             (setq obj (vlax-ename->vla-object (car subent))))
  10.        (if (vlax-property-available-p obj 'textstring)
  11.          (vla-get-textstring obj)
  12.        )
  13.       )
  14.     )
  15.   )
  16.
  17. (while (not done)
  18.   (cond
  19.     ((and (null string1)
  20.           (setq ent (entsel "\nSelect First attribute/Text : ")))
  21.       (setq string1 (_getString ent))
  22.      )
  23.     ((and string1 (null string2)
  24.           (setq ent (entsel "\nSelect Next attribute/Text : "))
  25.           (setq string2 (_getString ent)))
  26.      )
  27.     ((and string1 string2 (setq ip (getpoint "\nPick Text insertion point")))
  28.       (entmakex (list (cons 0 "TEXT")
  29.                   (cons 10  ip)
  30.                   (cons 40 (getvar "textsize"))
  31.                   (cons 1  (strcat string1 " + " string2))))
  32.      (setq done t)
  33.      )
  34.    ) ; cond
  35. ) ; while
  36.   (princ)
  37. )
  38.
  39. (princ " Type   CTXT    to invoke the lisp")
HasanCAD
« Reply #2 on: October 09, 2013, 09:06:57 AM »
Working good but the routine alow to select one more text
I want to pick more than one text
see attached
« Reply #3 on: October 09, 2013, 09:08:22 AM »
Try something like this for your loop
(while (not ATTr)
  (if (not (and (setq ATTr (car (nentsel str)))
(member
  (vla-get-objectname
    (setq ATTr nil)
As long as ATTr is nil, the loop will continue to run, once there is a valid value in ATTr the loop will exit.
You will need to ensure that ATTr is always nil upon entering the loop.
« Reply #4 on: October 09, 2013, 09:17:51 AM »
Another quick draft:
  1. (defun c:ctxt ( / _entsel ins nxt str )
  2.
  3.     (defun _entsel ( msg / ent )
  4.         (while
  5.             (progn
  6.                 (setvar 'errno 0)
  7.                 (setq ent (car (nentsel msg)))
  8.                 (cond
  9.                     (   (= 7 (getvar 'errno))
  10.                         (princ "\nMissed, try again.")
  11.                     )
  12.                     (   (= 'ename (type ent))
  13.                         (if (not (wcmatch (cdr (assoc 0 (entget ent))) "TEXT,ATTRIB"))
  14.                             (princ "\nInvalid object selected.")
  15.                         )
  16.                     )
  17.                 )
  18.             )
  19.         )
  20.         (if ent (cdr (assoc 1 (entget ent))))
  21.     )
  22.
  23.     (if (setq str (_entsel "\nSelect first attribute/text: "))
  24.         (progn
  25.             (while (setq nxt (_entsel "\nSelect next attribute/text <Done>: "))
  26.                 (setq str (strcat str " + " nxt))
  27.             )
  28.             (if (setq ins (getpoint "\nPick text insertion point: "))
  29.                 (entmake
  30.                     (list
  31.                        '(0 . "TEXT")
  32.                         (cons 10 (trans ins 1 0))
  33.                         (cons 40 (getvar 'textsize))
  34.                         (cons 01 str)
  35.                     )
  36.                 )
  37.             )
  38.         )
  39.     )
  40.     (princ)
  41. )
Only compatible in UCS parallel to WCS.
« Reply #5 on: October 09, 2013, 09:24:40 AM »
My rework:
  2.
  5.     (cond
  8.       ((and subent
  12.        )
  13.       )
  14.     )
  15.   )
  16.
  17. (setvar "errno" 0) ; must pre set the errno to 0
  18. (while (not done)
  19.   (cond
  20.     ((and (null string1)
  21.           (setq ent (entsel "\nSelect First attribute/Text : ")))
  22.       (setq string1 (_getString ent))
  23.      )
  24.     ((and string1 (null string2)
  25.           (setq ent (entsel "\nSelect Next attribute/Text : "))
  26.           (setq string2 (_getString ent)))
  27.      (setq string1 (strcat string1 " + " string2)
  28.            string2 nil)
  29.      )
  30.     ((= (getvar "errno") 52) ; exit if user pressed ENTER
  31.
  32.      (if (and string1
  33.               (setq ip (getpoint "\nPick Text insertion point")))
  34.       (entmakex (list (cons 0 "TEXT")
  35.                   (cons 10  ip)
  36.                   (cons 40 (getvar "textsize"))
  37.                   (cons 1  string1)))
  38.      )
  39.      (setq done t)
  40.      )
  41.    ) ; cond
  42. ) ; while
  43.   (princ)
  44. )
  45.
  46. (princ " Type   CTXT    to invoke the lisp")
HasanCAD
« Reply #6 on: October 09, 2013, 10:31:59 AM »
working perfect
Thnax CAB
Thanx LEE
« Reply #7 on: October 09, 2013, 10:49:31 AM »
Thnax CAB
Thanx LEE
*Thanks Keith™
  :wink:
You're welcome Hasan  :-)
« Reply #8 on: October 09, 2013, 11:28:10 AM »
That poor cat.  :)
HasanCAD
« Reply #9 on: October 10, 2013, 02:51:44 AM »
Special thanks for Keith™  :-D  :-)
