Author Topic: notepad++ question for anyone who uses it  (Read 5736 times)
andrew_nao
« on: June 20, 2013, 01:45:25 PM »
for anyone who uses notepad++ for coding, do you know of a way to have the commented text always be highlighted instead of being a set color?
right now any comment i leave in a file is green text, i would like to just have it highlighted
is this possible? im not seeing anyway but maybe someone else knows of a way
thanks
Re: notepad++ question for anyone who uses it
« Reply #1 on: June 20, 2013, 02:08:59 PM »
I'm guessing it would be as easy as modifying the xml file to reflect the desired background color.
For example, yellow (FFFF00) as the highlight (background) color:
<WordsStyle name="COMMENT" styleID="1" fgColor="008040" bgColor="FFFF00" fontName="" fontStyle="0" />
<WordsStyle name="COMMENT LINE" styleID="2" fgColor="008040" bgColor="FFFF00" fontName="" fontStyle="0" />
<shrug>
Also see this post.
andrew_nao
« Reply #2 on: June 20, 2013, 02:49:07 PM »
thanks
that didnt work though, i tried to import the your file you linked to and it screwed up my color coding completely LOL
i tried to uninstall and reinstall a newer version but my color codes still arent working
i did something to mess this up ... *sigh*
« Reply #3 on: June 20, 2013, 02:56:18 PM »
Sorry?
This is the first I've ever heard the file I provided screwed up someone's system.
If you can determine how my file is dekcuf up I'll fix it but I don't see anything wrong with it (acknowledging I don't use it myself as I use TextPad & UltraEdit or my ASCII bashing).
« Reply #4 on: June 20, 2013, 03:09:07 PM »
Assuming that you haven't defined your own language syntax file specifically for AutoLISP and that you are using the default LISP language defined in Notepad++ for opening .lsp files: go to Settings > Style Configurator; select LISP from the Language list and COMMENT from the Style list, then change the Background Color.
andrew_nao
« Reply #5 on: June 20, 2013, 04:15:38 PM »
Sorry?
i dont even know how it did either to even explain it. i followed the steps in your link that showed how to import it but all my text went to black and my color coding was gone
but i did get it back to normal i had to goto language> then L and click on the "lisp" flyout
@Lee, that didnt work either. i think what im asking isnt possible with this.
the commentline is what i was after to always be highlight not just a different color.
i just leave it as it.
thanks for the replies  :mrgreen:
« Reply #6 on: June 20, 2013, 05:06:12 PM »
Sorry, change the Background Colour of the COMMENTLINE Style, not the COMMENT Style.
Also, for 'Global Styles' in the Language list, ensure 'Enable global background colour' is disabled.
Result:
MeasureUp
« Reply #7 on: June 20, 2013, 08:16:37 PM »
Thanks and this is nice to learn.
What if I want to highlight the comments below? Is it possible?
atof       = a-tov
atoi       = A-toy
itoa       = I-T-O-A
rtos       = R-toz
distof     = diss-tov
irneb
« Reply #8 on: June 21, 2013, 05:27:35 AM »
Unfortunately I've not seen that working in Notepad++. It doesn't have a decent multiline comment parsing, at least not for AutoLisp.
In normal (built-in) Lisp mode it works fine for the #| .... |# multi-line comments. But I can't find a place to change that to use ;| ... |; instead. The only way I can get these to work is through a custom language (like the one in that other thread), but then you find it needs a double character for line comments: ;; ... otherwise the multiline version is ignored.
andrew_nao
« Reply #9 on: June 21, 2013, 10:05:23 AM »
Result:
thanks that worked.
MeasureUp
« Reply #10 on: June 23, 2013, 07:28:46 PM »
Thanks irneb.
smemo
  • Mosquito
« Reply #11 on: June 26, 2013, 03:00:44 AM »
on menu, "Language" -> "User Define Language", select Autolisp, Sheet "Comment & Number" on section "Commet Block"  button "Styler"
irneb
« Reply #12 on: June 26, 2013, 04:11:37 AM »
As I stated, yes it works. But then it doesn't work for single ; comments. If you then change the comment line to allow for single ; comment, then the multi-line comments don't work anymore.
irneb
« Reply #13 on: June 26, 2013, 04:20:51 AM »
The way where the built-in Lisp gets around this is by using the CL's multi-line comment style. But of course that one doesn't work with AutoLisp, as ACad does not read this as a comment mark.
It's a "bug" in Notepad++ (IMO). It uses the comment line's tag as override to everything else. It should have used the comment start/stop tag as override, then this issue wouldn't have been  an issue.
