Author Topic: ascending sorting dynamic blocks ( by diameters and lenght )and rename the block  (Read 2869 times)
serge_c
Need guru's help . I make a lot of movements arrive at the final result, but i am sure it possible to make the shortest way :
if it's possible to select the blocks and automatically the lisp will sort the block by diameter and lenght and after that  if is possible to imput the number which will begin the renumbering !!!
Thanks in advance !!!
BIGAL
  • 40 + years of using Autocad
Here is an example of sort on 2 items.
(setq lst (list '(20 123) '(25 345) '(10 456) '(8 234)))
; sorts on 1st two items
(setq lst (vl-sort lst
'(lambda (a b)
      ((< (car a) (car b)))
      ((= (car a) (car b)) (< (cadr a) (cadr b)))
serge_c
BIGAL thanks for this example but I think, I will not succeed by my self.
I make some simple lisp , but this i gonna be to complicated for me , Taht why  I am asking for your level ""GURU's LEVEL""
HOSNEYALAA
HI
TEST THIS
(defun c:test (/ A11 A2 A3 ACDBBLOCKREFERENCE ATTDATA ATTRIBUTES^ ATTS LST PATTERN SS0)
 (if  (and
       (progn (initget 7)  (setq pattern(getint  "\nSpecify input NO : ")))
       (setq ss0 (ssget '((0 . "insert") (66 . 1))))
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss0)))
;;;      (setq ename (mapcar'vlax-ename->vla-object(vl-remove-if 'listp (mapcar 'cadr (ssnamex ss0))))
    (setq AcDbBlockReference (vlax-ename->vla-object ename))
;;;    (setq attributes^ (vlax-invoke AcDbBlockReference 'GetAttributes))
           (setq atts (vlax-invoke AcDbBlockReference 'getattributes))
           (foreach att atts
                   ((wcmatch (vla-get-tagstring att) "DIAMETRU")
                    (setq a2 (vla-get-textstring att))
                   ((wcmatch (vla-get-tagstring att) "Lungimea")
                    (setq a3 (vla-get-textstring att))
           (setq attdata (cons (list (atof a2) (atof a3) AcDbBlockReference) attdata))
;;;(setq attdata nil)
   ;;BIGAL
      (setq lst (vl-sort attdata
'(lambda (a b)
   (foreach ename (mapcar 'caddr lst)
;;;      (setq ename (caDr (mapcar 'caddr lst)))
           (setq atts (setq attributes^ (vlax-invoke ename 'GetAttributes)))
           (foreach att atts
;;;      (setq att (car atts))
             (cond ((wcmatch (setq a11(vla-get-tagstring att)) "Pozitia")
                     (vla-put-textstring att (RTOS pattern 2 0 ))
     (setq pattern (+ 1 pattern))
  ); progn
 ); if
HOSNEYALAA
serge_c
Hi HOSNEYALAA !!!
it's work but final result is not like in the example.
the duplicated position should  be deleted.
apreciate your work , can you finish it please ?
HOSNEYALAA
What is the required result
After you work soring
If you explain with a picture or a drawing
Because I am not good at English
serge_c
I mark how is the result after your lisp , and how it should be
HOSNEYALAA
hi
this this
 ;; HOSNEYALAA 23.10.2020 ;;
 (if  (and
           (foreach att atts
   ;;BIGAL
'(lambda (a b)
(setq  a  (car(car lst)) b (cadar lst))
   (foreach ename lst
;;;      (setq ename (cadr lst))
           (setq atts (setq attributes^ (vlax-invoke (caddr ename) 'GetAttributes)))
           (foreach att atts
             ( if     (and (wcmatch (setq a11(vla-get-tagstring att)) "Pozitia") (equal a (setq ach  (car ename))) (equal b (setq bch  (cadr ename))))
  (setq a ach
                                b bch
        );;progn
   (or (/= a (setq ach  (car ename))) (/= b (setq bch  (cadr ename))))
                             (vla-put-textstring att (RTOS (setq pattern (+ 1 pattern)) 2 0 ))
(setq a ach
                                b bch
        );;progn
         );;;(foreach
     );;;; progn
  ) ;;;(foreach
      );;;; progn
 ); if
« Last Edit: October 23, 2020, 12:12:41 PM by HOSNEYALAA »
HOSNEYALAA
serge_c
Hi again  HOSNEYALAA!!!
You aproximaximatelly done it !!!
but some positions still repeating .In the image you will understand.
serge_c
your result
HOSNEYALAA
HI
TEST THIS
WRONG THIS
  (setq a ach
                                b bch
        );;progn
 (if  (and
           (foreach att atts
           (setq attdata (cons (list (rtos (atof a2) 2 0) (rtos (atof a3) 2 0) AcDbBlockReference) attdata))
   ;;BIGAL
'(lambda (a b)
   (foreach ename lst
;;;      (setq ename (nth 10 lst))
           (foreach att atts
             ( if     (and (wcmatch (setq a11(vla-get-tagstring att)) "Pozitia") (equal a (car ename)) (equal b (cadr ename)))
        );;progn
   (or (/= a (car ename) ) (/= b (cadr ename)))
     (setq a (car ename))
                             (setq b (cadr ename))
        );;progn
         );;;(foreach
     );;;; progn
  ) ;;;(foreach
      );;;; progn
 ); if
HOSNEYALAA
serge_c
little modification," please " the lenght are little bit not ascending, must see in the picture , your result
« Last Edit: October 26, 2020, 11:03:51 AM by sergiu_ciuhnenco »
