Author Topic: [challenge] subtract rle2  (Read 1687 times)
well20152016
« on: January 04, 2022, 02:43:23 AM »
;;;(rle1 '(a a a a b c c a a d e e e e))
;;;((A 6) (B 1) (C 2) (D 1) (E 4))
Code - XML: [Select]
  1. (rle2 (setq l1 (list '(A 6) '(B 2) '(C 2) '(D 1) '(E 4))) (setq l2 (list '(A 15) '(B 11) '(C 12) '(D 11) '(E 41) '(F 31) '(G 44))))
  2. (
  3. (    ((A 6) (B 2) (C 2) (D 1) (E 4))     2)             Simultaneous existence 2 l1            non-existent   return nil
  4.  ((A 3) (B 7) (C 8) (D 9) (E 33) (F 31) (G 44))      surplus
  5. )
  1.
  2. (defun rle2 (l1 l2)
  3. (setq l4 l2)
  4. (if (apply 'and (setq l3 (mapcar'(lambda (x) (car(vl-remove-if-not '(lambda (y)(= (car y) (car x)) )l2))) l1)))
  5.   (progn
  6.     (setq ll (apply 'min (mapcar'(lambda(x y) (/(cadr y)(cadr x)))l1 l3)))
  7.     (if (> ll 0)(progn
  8.                   (list (list l1 ll) (mapcar'(lambda(x)(if (setq l4 (vl-remove-if-not'(lambda (y)(= (car y) (car x)))l1)) (list (car x) (- (cadr x)(* ll(cadar l4)))) x))l2))
  9.      )
  10.       (list nil l2))
  11.   )
  12.  )
  13. )
  14.
« Last Edit: January 05, 2022, 09:28:13 AM by well20152016 »
Re: [challenge] subtract rle2
« Reply #1 on: January 04, 2022, 10:59:36 AM »
I'm not sure I followed the spirit of the challenge (I don't think I understood your intent) but here's mine.
(setq lst1 '((A 6) (B 1) (C 2) (D 1) (E 4)))
(setq lst2 '((A 3) (B 1) (C 1) (D 1) (E 3)))
> ((A 3) nil c nil E)
  1. (defun subt-rle-list (lst1 lst2)
  2.   (mapcar
  3.     (function
  4.       (lambda ( x y )
  5.         (if (< (cadr y) (cadr x))
  6.           (if (= 1 (- (cadr x) (cadr y)))
  7.             (car x)
  8.             (list (car x) (- (cadr x) (cadr y)))))))
  9.     lst1 lst2))
« Reply #2 on: January 04, 2022, 01:51:26 PM »
  1. (defun _foo-rjp (l / a r)
  2.   (while (> (setq a (length l)) 0)
  3.     (setq r (cons (list (car l) (- a (length (setq l (vl-remove (car l) l))))) r))
  4.   )
  5.   (reverse r)
  6. )
  7. (_foo-rjp (setq l '(a a a a b c c a a d e e e e)))
  8. ;; ((A 6) (B 1) (C 2) (D 1) (E 4))
« Reply #3 on: January 04, 2022, 02:23:37 PM »
Okay, that is confusing. How do you decompress that output?
EDIT: Spelling error
« Last Edit: January 05, 2022, 09:35:52 AM by JohnK »
well20152016
« Reply #4 on: January 05, 2022, 09:31:32 AM »
> ((A 3) nil c nil E)
(setq lst1 '((A 6) (B 1) (C 2) (D 2) (E 4)))
(setq lst2 '((A 9) (B 2) (C 2) (D 1) (E 5))) >  ((A 3) (B 1) (C 0) nil (E 1))
(nil  '((A 9) (B 2) (C 2) (D 1) (E 5)))
(setq lst2 '((A 15) (B 3) (C 4) (D 5) (E 9))) >  ((A 3) (B 1) (C 0) (D 1) (E 1))
(('((A 6) (B 1) (C 2) (D 2) (E 4)) 2)  ' ((A 3) (B 1) (C 0) (D 1) (E 1)))
Simultaneous existence,No nil
« Last Edit: January 05, 2022, 09:38:06 AM by well20152016 »
« Reply #5 on: January 05, 2022, 10:10:26 AM »
In this this instance why does c = 0 and d = nil?
How does
        A: 6 - 15 = 3?
        B: 1 - 3 = 1?
        C: 2 - 4 = 0?
This is not run-Length encoding! I am sorry, but I am confused about so many aspects of this thread.
ssdd
« Reply #6 on: January 05, 2022, 10:46:06 AM »
 A 15-2*6=3
 B 3-2*1=1
C 4-2*2=0
D 5-2*2=1
E 9-2*4=1
« Reply #7 on: January 05, 2022, 12:28:16 PM »
A 15-2*6=3
 B 3-2*1=1
C 4-2*2=0
D 5-2*2=1
E 9-2*4=1
I think I see now but how do you then decode the result? And what does Run Length Encoding have to do with this operation?
How does: ((A 3) (B 1) (C 0) (D 1) (E 1))
get back to: ((A 6)  (B 1) (C 2) (D 2) (E 4))
or: ((A 15) (B 3) (C 4) (D 5) (E 9))
well20152016
« Reply #8 on: January 05, 2022, 10:41:25 PM »
A 15-2*6=3
 B 3-2*1=1
C 4-2*2=0
D 5-2*2=1
E 9-2*4=1
get back   (list
        ((A 3) (B 1) (C 0) (D 1) (E 1))   ------surplus
       (    ((A 6)  (B 1) (C 2) (D 2) (E 4))  2 )  ------ ((A 6)  (B 1) (C 2) (D 2) (E 4))      There are two
