I created an Image Tile in my mnu file which uses slides from a slide library that I created.
After I make the necessary changes; I load the mnu into ACAD (as a partial) then it converts to a cui.
When I call the Image Tile from my pulldown in ACAD; it appears, all the slides are appearing, however, instead of all of my friendly names appearing, the word cover shows up where all the friendly names should be appearing.
Has anyone ever seen this happen?
Also, does anyone know the fix?
Thank you,
