Author Topic: Array with Pline as Path  (Read 2580 times)
A_LOTA_NOTA
« on: May 09, 2008, 11:11:47 AM »
I have a circle I would like to array using a PLine as my path. Does anyone have a lisp that will do that?
Re: Array with Pline as Path
« Reply #1 on: May 09, 2008, 11:13:00 AM »
Have a look at MEASURE.
A_LOTA_NOTA
« Reply #2 on: May 09, 2008, 11:23:41 AM »
I already tried that but at first glance, it looked like the spacing at the corners was wrong. But after breaking it up & listing the lines, I see they are the same length. I think it will work for what I'm trying to do.
