CAD Forums => CAD General => Topic started by: billabong on July 31, 2007, 06:28:04 AM
There could be a particularly easy fix for this and MS is just bugging me for no reason (surprise surprise)
But I cant solid hatch a selected area.....Does MS have this function?? hatch, crosshatch...but no solid. :pissed:
MS does have this ability :-)
You'll need to set the filltype to solid via the change attributes (see piccy below)
Hope this helps :-)
Yeah for elements thats perfect, but I'm trying to hatch an area (namely a lane of a road)
So I need to pick a point inside, it will find the area and flood it with solid.
Try this...
(http://www.theswamp.org/screens/Arizona/solid.jpg)
Hope this helps :-)
This did work, I had to define the region first and then use the active fill type command.
Cheers
