Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help: id mleader lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help: id mleader lisp (Read 703 times)
mhy3sx
Newt
on:
May 29, 2023, 11:44:37 AM »
Hi, I am using this code to id coordinates. This code use leader and mtext. Is it possible to use mleader ? I don't want the line and mtext to be separate
Code - Auto/Visual Lisp:
[Select]
defun
c:idd
setq
lup
getvar
"luprec"
setvar
"luprec"
3
setq
zin
getvar
"dimzin"
setvar
"dimzin"
0
setvar
"cmdecho"
0
setq
po
getpoint
"Pick First Point:"
setq
po2
getpoint
po
"Pick Second Point:"
setq
xp
strcat
"N "
rtos
cadr
po
2
3
setq
yp
strcat
"E "
rtos
car
po
2
3
command
"leader"
po po2
yp xp
Logged
Tharwat
Swamp Rat
Hypersensitive
WWW
Re: Help: id mleader lisp
Reply #1 on:
May 29, 2023, 01:45:31 PM »
If you want the two strings to inline then just remove the "\\P" from the command.
[Select]
command
"Mleader"
po po2
strcat
yp
P"
xp
Logged
HVAC, Plumbing, Drainage, Electricity , Fire Fighting Programs and many more .....
mhy3sx
Newt
Reply #2 on:
May 29, 2023, 04:02:25 PM »
Thanks Tharwat
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
