Author Topic: General Notes, how do you do them?  (Read 4276 times)
Willie
  • Going nowhere slowly
Re: General Notes, how do you do them?
« Reply #15 on: May 04, 2009, 10:39:11 PM »
We have a couple of notes saved on our template.  Normally we fine tune the notes as per the project and drawing requirements. Seems to work OK.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Daniel J. Ellis
« Reply #16 on: May 05, 2009, 03:09:03 AM »
My current doesn't use them, we don't need to because of the nature of work we do, but in previous firms we've used xrefs.
dJE
dJE
Alan Cullen
« Reply #17 on: May 05, 2009, 04:17:28 AM »
dJE
I couldn't think of anything worse than using general notes as x-refs.  :?
P.S. I hate x-refs at the best of times. I'm civil and we have no need for them.  :-P
jonesy
  • SuperMod
« Reply #18 on: May 05, 2009, 04:59:54 AM »
Our notes are in tables. Delete the row that is not needed in the drawing, and I'm done
CADaver
« Reply #19 on: May 05, 2009, 08:53:32 PM »
wha ... ahhh never mind
Slim©
  • The Dude Abides...
« Reply #20 on: May 05, 2009, 09:09:44 PM »
Being from a Civil/Survey background, I have found that when Existing Topo and Boundary drawings were XREFed into the Proposed plan drawings the accidental loss of information was prevented. When working in the Land Survey Dept. Survey Techs were the only ones that could edit said survey drawings. If an Engineer needed additional information it could be made available to them. I have witnessed on numerous occasions the accidental loss of information by Engineers because of their need to hit a deadline. It doesn't happen all of the time, and yes there are and have been backups. Just my $0.02.
It also helps when General notes are involved. You only have to edit one drawing file not every one in the set.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #21 on: May 05, 2009, 10:10:52 PM »
Thanks Randy, If I can ignore it so can you :)
Called Kerry in my other life
I live at UTC + 13.00
