Author Topic: can anyone help with a more elegant way to do this?  (Read 5518 times)
dgorsman
Re: can anyone help with a more elegant way to do this?
« Reply #15 on: June 21, 2011, 04:02:00 PM »
Watch your brackets.  Putting brackets around something denotes a function call, or creating a quoted list.  Of course, a string is neither, so it throws a fit.  To create a list of strings, just provide the strings to the list.
i can get my code to work unless the list (oldblock_lst) is in brackets
im trying all different things to change this to get it to work but nothing is working so far
do you have any suggestions?
Playing out a little more line to make the fishing easier.   :-)
Read up on string and list-of-string type data, so you can understand the differences between them and how they look in LISP.  Put together some simple foo-examples to work with.  That will help with locating the brackets in the correct quatities and locations.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
