Author Topic: Help: Set drawing scale DCL lisp  (Read 674 times)
mhy3sx
« on: April 13, 2024, 12:49:24 PM »
Hi, I am writing a dcl lisp to set the scale of the drawing, but I have this error
Error: malformed list on input.
  1. (defun c:SETSC (/ *error* dch dcl des)
  2.   (defun *error* (msg)
  3.     (if (and (= 'int (type dch)) (< 0 dch))
  4.       (unload_dialog dch)
  5.     )
  6.     (if (= 'file (type des))
  7.       (close des)
  8.     )
  9.     (if (and (= 'str (type dcl)) (findfile dcl))
  10.       (vl-file-delete dcl)
  11.     )
  12.     (if (and msg
  13.              (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  14.         )
  15.       (princ (strcat "\nError: " msg))
  16.     )
  17.     (princ)
  18.   )                                     ; end defun
  19.
  20.   (cond
  21.     ((not
  22.        (setq dcl (vl-filename-mktemp nil nil ".dcl")
  23.              des (open dcl "w")
  24.        )                                ; end setq
  25.      )                                  ; end not
  26.      (princ "\nUnable to open DCL for writing.")
  27.     )
  28.     ((progn
  29.        (foreach str
  30.                 '(
  31.                   "ed : edit_box { alignment = left; width = 20; edit_width = 10; fixed_width = true;}"
  32.                   ""
  33.                   "setscale : dialog { spacer; key = \"dcl\";"
  34.                   " : boxed_radio_column { key=\042key\042; label = \"Select Drawing Scale;\"; height = 1.0;"
  35.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  36.                   "        key = \"radio_button01\"; label = \"1. --> 1:50\";"
  37.                   "    }"
  38.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  39.                   "        key = \"radio_button02\"; label = \"2. --> 1:100\";"
  40.                   "    }"
  41.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  42.                   "        key = \"radio_button03\"; label = \"3. --> 1:200\";"
  43.                   "    }"
  44.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  45.                   "        key = \"radio_button04\"; label = \"4. --> 1:250\";"
  46.                   "    }"
  47.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  48.                   "        key = \"radio_button05\"; label = \"5. --> 1:500\";"
  49.                   "    }"               ; radio_button
  50.                   "      : radio_button  { height = 1.0; width = 20; is_tab_stop = true;"
  51.                   "        key = \"radio_button06\"; label = \"6. --> 1:2000\";"
  52.                   "    }"               ; radio_button
  53.                   "      : radio_button  { height = 1.0; width = 20; is_tab_stop = true;"
  54.                   "        key = \"radio_button07\"; label = \"7. --> 1:2500\";"
  55.                   "    }"               ; radio_button
  56.                   "      : radio_button  { height = 1.0; width = 20; is_tab_stop = true;"
  57.                   "        key = \"radio_button08\"; label = \"8. --> 1:5000\";"
  58.                   "    }"               ; radio_button
  59.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  60.                   "        key = \"radio_button09\"; label = \"9. --> 1:10000\";"
  61.                   "    }"               ; radio_button
  62.                   "      : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
  63.                   "        key = \"radio_button10\"; label = \"10. --> 1:50000\";"
  64.                   "    }"               ; radio_button
  65.                   "      : ed {height = 1.0; width = 20; is_tab_stop = true;key = \"other\"; label = \"Other:\"; }"
  66.                   "      }"             ;end boxed_column
  67.                   "    ok_only;"
  68.                   "  }"                 ; end dialog
  69.                  )                      ;end list
  70.          (write-line str des)
  71.        )                                ; end foreach
  72.        (setq des (close des)
  73.              dch (load_dialog dcl)
  74.        )                                ; end setq
  75.        (<= dch 0)
  76.      )
  77.      (princ "\nUnable to load DCL file.")
  78.     )
  79.     ((not (new_dialog "setscale" dch))
  80.      (princ "\nUnable to display 'setscale' dialog.")
  81.     )
  82.     (t
  83.      (set_tile "dcl" "Select Drawing Scale")
  84.      (action_tile "key" "(setq sngReturn $value)")
  85.      (action_tile "OK" "(done_dialog 1)")
  86.      (start_dialog)
  87.
  88.      (setvar "OSMODE" 13)
  89.
  90.      (princ "\n The dawing scale set 1:")(princ newsc)(princ)
  91.      (if (setq sngReturn (cond ((eq sngReturn "radio_button01") 50)
  92.                            ((eq sngReturn "radio_button02") 100)
  93.                            ((eq sngReturn "radio_button03") 200)
  94.                            ((eq sngReturn "radio_button04") 250)
  95.                            ((eq sngReturn "radio_button05") 500)
  96.                            ((eq sngReturn "radio_button06") 2000)
  97.                            ((eq sngReturn "radio_button07") 2500)
  98.                            ((eq sngReturn "radio_button08") 5000)
  99.                            ((eq sngReturn "radio_button09") 10000)
  100.                            ((eq sngReturn "radio_button10") 50000)
  101.                            ((eq sngReturn "other") (setq sngReturn (get_tile "other"))
  102.                      )
  103.      )
  104. )
  105.
  106.                  (princ "\nThe drawing scale is 1:")(princ sngReturn)
  107.         (setq newsc (getint "\nThe new scale is  1:"))
  108.         (setvar "useri1" newsc)
  109.     )
  110.   ) ; end cond
  111.   (*error* nil)
  112. )
  113.
  114.
  115.
Any ideas?
BIGAL
  • 40 + years of using Autocad
Re: Help: Set drawing scale DCL lisp
« Reply #1 on: April 13, 2024, 07:57:29 PM »
Just use this, it can be used in any code just save to a support path so autoloads. Just look at the examples say the 1 2 3 .........
mhy3sx
« Reply #2 on: April 14, 2024, 05:00:59 AM »
Hi BIGAL, I have seen this code before but I can not understand it. Can you Help me with my code?
ribarm
  • Marko Ribar, architect
« Reply #3 on: April 14, 2024, 06:03:21 AM »
Here is your code debugged...
I hope you'll learn something - that error of yours is common for unbalanced brackets, but you had more lacks...
What I discovered more is that EDIT BOX don't work in BricsCAD, but works as desired in AutoCAD - tested on release 2022...
  1. (defun c:SETSC (/ *error* dch dcl des sng sngReturn )
  2.
  3.   (defun *error* (msg)
  4.     (if (and (= 'int (type dch)) (< 0 dch))
  5.       (unload_dialog dch)
  6.     )
  7.     (if (= 'file (type des))
  8.       (close des)
  9.     )
  10.     (if (and (= 'str (type dcl)) (findfile dcl))
  11.       (vl-file-delete dcl)
  12.     )
  13.     (if (and msg
  14.              (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  15.         )
  16.       (princ (strcat "\nError: " msg))
  17.     )
  18.     (princ)
  19.   )
  20.
  21.   (cond
  22.     ((not
  23.        (setq dcl (vl-filename-mktemp nil nil ".dcl")
  24.              des (open dcl "w")
  25.        )
  26.      )
  27.      (princ "\nUnable to open DCL for writing.")
  28.     )
  29.     ((progn
  30.        (foreach str
  31.                 '(
  32.                   "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}"
  33.                   ""
  34.                   "setscale : dialog { spacer; key = \"dcl\";"
  35.                   " : boxed_radio_column { key=\042key\042; label = \"Select Drawing Scale\"; height = 1.0;"
  36.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  37.                   "        key = \"radio_button01\"; label = \"1. --> 1:50\";"
  38.                   "    }"
  39.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  40.                   "        key = \"radio_button02\"; label = \"2. --> 1:100\";"
  41.                   "    }"
  42.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  43.                   "        key = \"radio_button03\"; label = \"3. --> 1:200\";"
  44.                   "    }"
  45.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  46.                   "        key = \"radio_button04\"; label = \"4. --> 1:250\";"
  47.                   "    }"
  48.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  49.                   "        key = \"radio_button05\"; label = \"5. --> 1:500\";"
  50.                   "    }"
  51.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  52.                   "        key = \"radio_button06\"; label = \"6. --> 1:2000\";"
  53.                   "    }"
  54.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  55.                   "        key = \"radio_button07\"; label = \"7. --> 1:2500\";"
  56.                   "    }"
  57.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  58.                   "        key = \"radio_button08\"; label = \"8. --> 1:5000\";"
  59.                   "    }"
  60.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  61.                   "        key = \"radio_button09\"; label = \"9. --> 1:10000\";"
  62.                   "    }"
  63.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  64.                   "        key = \"radio_button10\"; label = \"10. --> 1:50000\";"
  65.                   "    }"
  66.                   "      : ed {height = 1.0; width = 25; is_tab_stop = true;"
  67.                   "        key = \"other\"; label = \"Other:\";"
  68.                   "    }"
  69.                   "      }"
  70.                   "    ok_only;"
  71.                   "  }"
  72.                  )
  73.          (write-line str des)
  74.        )
  75.        (setq des (close des)
  76.              dch (load_dialog dcl)
  77.        )
  78.        (<= dch 0)
  79.      )
  80.      (princ "\nUnable to load DCL file.")
  81.     )
  82.     ((not (new_dialog "setscale" dch))
  83.      (princ "\nUnable to display 'setscale' dialog.")
  84.     )
  85.     (t
  86.      (set_tile "dcl" "Select Drawing Scale")
  87.      (action_tile "key" "(progn (setq sngReturn (atoi (get_tile \"other\"))) (setq sng $value))")
  88.      (action_tile "OK" "(done_dialog 1)")
  89.      (start_dialog)
  90.      (if
  91.        (setq sngReturn
  92.          (cond
  93.            ( (eq sng "radio_button01") 50 )
  94.            ( (eq sng "radio_button02") 100 )
  95.            ( (eq sng "radio_button03") 200 )
  96.            ( (eq sng "radio_button04") 250 )
  97.            ( (eq sng "radio_button05") 500 )
  98.            ( (eq sng "radio_button06") 2000 )
  99.            ( (eq sng "radio_button07") 2500 )
  100.            ( (eq sng "radio_button08") 5000 )
  101.            ( (eq sng "radio_button09") 10000 )
  102.            ( (eq sng "radio_button10") 50000 )
  103.            ( (eq sng "other") sngReturn )
  104.          )
  105.        )
  106.        (progn
  107.          (princ "\nThe drawing scale is 1:")(princ sngReturn)
  108.          (setvar "useri1" sngReturn)
  109.          (initget 4)
  110.          (if (setq newsc (getint "\nThe new scale is (ENTER to discard) 1:"))
  111.            (setvar "useri1" newsc)
  112.          )
  113.        )
  114.      )
  115.     )
  116.   )
  117.   (*error* nil)
  118. )
  119.
HTH.
M.R.
« Last Edit: April 14, 2024, 10:15:31 AM by ribarm »
M.R. on Youtube
mhy3sx
« Reply #4 on: April 14, 2024, 12:06:48 PM »
Hi ribarm. I test your code . I  see that the other scale is not working in ZWCAD I use. I add some more things in the code but the other scale not working.
Any other ideas how to fix this problem?
  1. (defun c:SETSC (/ *error* dch dcl des sng sngReturn cursc newsc)
  5.     )
  7.       (close des)
  8.     )
  11.     )
  12.     (if (and msg
  14.         )
  16.     )
  17.     (princ)
  18.   )
  19.
  20.   (setvar "OSMODE" 13)
  21.   (setq cursc (getvar "useri1"))
  22.
  23.   (cond
  24.     ((not
  25.        (setq dcl (vl-filename-mktemp nil nil ".dcl")
  26.              des (open dcl "w")
  27.        )
  28.      )
  29.      (princ "\nUnable to open DCL for writing.")
  30.     )
  31.     ((progn
  32.        (foreach str
  33.                 '(
  34.                   "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}"
  35.                   ""
  36.                   "setscale : dialog { spacer; key = \"dcl\";"
  37.                   " : boxed_radio_column { key=\042key\042; label = \"Select Drawing Scale\"; height = 1.0;"
  38.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  39.                   "        key = \"radio_button01\"; label = \"1. --> 1:50\";"
  40.                   "    }"
  41.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  42.                   "        key = \"radio_button02\"; label = \"2. --> 1:100\";"
  43.                   "    }"
  44.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  45.                   "        key = \"radio_button03\"; label = \"3. --> 1:200\";"
  46.                   "    }"
  47.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  48.                   "        key = \"radio_button04\"; label = \"4. --> 1:250\";"
  49.                   "    }"
  50.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  51.                   "        key = \"radio_button05\"; label = \"5. --> 1:500\";"
  52.                   "    }"
  53.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  54.                   "        key = \"radio_button06\"; label = \"6. --> 1:2000\";"
  55.                   "    }"
  56.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  57.                   "        key = \"radio_button07\"; label = \"7. --> 1:2500\";"
  58.                   "    }"
  59.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  60.                   "        key = \"radio_button08\"; label = \"8. --> 1:5000\";"
  61.                   "    }"
  62.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  63.                   "        key = \"radio_button09\"; label = \"9. --> 1:10000\";"
  64.                   "    }"
  65.                   "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
  66.                   "        key = \"radio_button10\"; label = \"10. --> 1:20000\";"
  67.                   "    }"
  68.                   "      : ed {height = 1.0; width = 25; is_tab_stop = true;"
  69.                   "        key = \"other\"; label = \"Other:\";"
  70.                   "    }"
  71.                   "      : ed {height = 1.0; width = 25; is_enabled = false;"
  72.                   "        key = \"oldscale\"; label = \"Old Scale:\";"
  73.                   "    }"
  74.                   "      }"
  75.                   "    ok_only;"
  76.                   "  }"
  77.                  )
  78.          (write-line str des)
  79.        )
  80.        (setq des (close des)
  81.              dch (load_dialog dcl)
  82.        )
  83.        (<= dch 0)
  84.      )
  85.      (princ "\nUnable to load DCL file.")
  86.     )
  87.     ((not (new_dialog "setscale" dch))
  88.      (princ "\nUnable to display 'setscale' dialog.")
  89.     )
  90.     (t
  91.      (set_tile "dcl" "Select Drawing Scale")
  92.      (set_tile "oldscale" (itoa cursc)) ; set the old scale in the dialog box
  93.      (action_tile "key" "(progn (setq sngReturn (atoi (get_tile \"other\"))) (setq sng $value))")
  94.      (action_tile "OK" "(done_dialog 1)")
  95.      (start_dialog)
  96.      (if
  97.        (setq sngReturn
  98.          (cond
  99.            ( (eq sng "radio_button01") 50 )
  100.            ( (eq sng "radio_button02") 100 )
  101.            ( (eq sng "radio_button03") 200 )
  102.            ( (eq sng "radio_button04") 250 )
  103.            ( (eq sng "radio_button05") 500 )
  104.            ( (eq sng "radio_button06") 2000 )
  105.            ( (eq sng "radio_button07") 2500 )
  106.            ( (eq sng "radio_button08") 5000 )
  107.            ( (eq sng "radio_button09") 10000 )
  108.            ( (eq sng "radio_button10") 20000 )
  109.            ( (eq sng "other") sngReturn)
  110.            ( (eq sng "oldscale") cursc)
  111.          )
  112.        )
  113.        (progn
  114.          (princ "\nThe drawing scale is 1:")(princ sngReturn)
  115.          (setvar "useri1" sngReturn)
  116.        )
  117.      )
  118.     )
  119.   )
  120.   (*error* nil)
  121. )
  122.
  123.
  124.
Thansk
« Last Edit: April 14, 2024, 12:14:05 PM by mhy3sx »
ribarm
« Reply #5 on: April 14, 2024, 12:21:00 PM »
Get AutoCAD...
M.R. on Youtube
mhy3sx
« Reply #6 on: April 14, 2024, 01:08:35 PM »
I fix the problem  :smitten: :smitten: :smitten:
  5.     )
  7.       (close des)
  8.     )
  11.     )
  12.     (if (and msg
  14.         )
  16.     )
  17.     (princ)
  18.   )
  19.
  22.
  23.   (cond
  24.     ((not
  27.        )
  28.      )
  30.     )
  31.     ((progn
  32.        (foreach str
  33.                 '(
  35.                   ""
  40.                   "    }"
  43.                   "    }"
  46.                   "    }"
  49.                   "    }"
  52.                   "    }"
  55.                   "    }"
  58.                   "    }"
  61.                   "    }"
  64.                   "    }"
  67.                   "    }"
  70.                   "    }"
  73.                   "    }"
  74.                   "      }"
  75.                   "    ok_only;"
  76.                   "  }"
  77.                  )
  79.        )
  82.        )
  83.        (<= dch 0)
  84.      )
  86.     )
  89.     )
  90.     (t
  93.         (action_tile "other" "(progn (setq sng \"other\") (setq sngReturn (atoi $value)))")
  94.         (action_tile "key" "(setq sng $value)")
  95.      (action_tile "OK" "(done_dialog 1)")
  96.
  97.      (start_dialog)
  98.
  99.      (if
  100.        (setq sngReturn
  101.          (cond
  102.            ( (eq sng "radio_button01") 50 )
  103.            ( (eq sng "radio_button02") 100 )
  104.            ( (eq sng "radio_button03") 200 )
  105.            ( (eq sng "radio_button04") 250 )
  106.            ( (eq sng "radio_button05") 500 )
  107.            ( (eq sng "radio_button06") 2000 )
  108.            ( (eq sng "radio_button07") 2500 )
  109.            ( (eq sng "radio_button08") 5000 )
  110.            ( (eq sng "radio_button09") 10000 )
  111.            ( (eq sng "radio_button10") 20000 )
  112.            ( (eq sng "other") sngReturn)
  113.            ( (eq sng "oldscale") cursc)
  114.          )
  115.        )
  116.        (progn
  117.          (princ "\nThe drawing scale is 1:")(princ sngReturn)
  118.          (setvar "useri1" sngReturn)
  119.        )
  120.      )
  121.     )
  122.   )
  123.   (*error* nil)
  124. )
  125.
  126.
BIGAL
« Reply #7 on: April 14, 2024, 11:37:16 PM »
Something I played with is make a dcl based on Autocad objects so for Radio button dcl it would look like the attached. it has radio buttons and a edit box example. You will see it has Blocks and text. In the case of the edit boxes uses the scale for the size of the box.
In radio button follow prompts just select buttons and labels when asked use window etc, the dcl should display.
This is real time to make a dcl.
« Last Edit: April 16, 2024, 02:52:01 AM by BIGAL »
mhy3sx
« Reply #8 on: April 15, 2024, 11:02:28 AM »
Hi, BIGAL can you post a *.dwg example?
BIGAL
« Reply #9 on: April 16, 2024, 02:53:08 AM »
Thought I did but added to prior post. Note the dcl is written to a directory of my choice d:\acadtemp change to suit.
