Author Topic: Selection Filter vs. Btr Iterating  (Read 3387 times)
Jeff H
« on: January 29, 2011, 09:59:18 PM »
Well I guess they both iterate so title is not correct.
I used drawing random points.dwg from this Post
Testing to fill a Point3dCollection
Maybe not a good test(Sure someone will reply if not), but using a SelectionFilter at least took 2 as long sometimes more.
[CommandMethod("TimeTest")]
 public void TimeTest()
     Point3dCollection pntsSS = new Point3dCollection();
     Point3dCollection pntsIter = new Point3dCollection();
     Database db = doc.Database;
     Editor ed = doc.Editor;
     using (Transaction trx = db.TransactionManager.StartTransaction())
         Stopwatch sw = Stopwatch.StartNew();
         BlockTableRecord btr = trx.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
         foreach (ObjectId id in btr)
             DBPoint dbPnt = trx.GetObject(id, OpenMode.ForRead) as DBPoint;
             if (dbPnt != null)
                 pntsIter.Add(dbPnt.Position);
         sw.Stop();
         ed.WriteMessage("\nItterating " + sw.ElapsedMilliseconds.ToString());
         sw.Reset();
         sw.Start();
         SelectionFilter sf = new SelectionFilter(new TypedValue[] { new TypedValue((int)DxfCode.Start, "POINT") });
         PromptSelectionResult psr = ed.SelectAll(sf);
         foreach (SelectedObject so in psr.Value)
             DBPoint dbPnt = trx.GetObject(so.ObjectId, OpenMode.ForRead) as DBPoint;
             pntsSS.Add(dbPnt.Position);
         sw.Stop();
         ed.WriteMessage("\nSelection Filter " + sw.ElapsedMilliseconds.ToString());
         trx.Commit();
It's Alive!
  • Retired
  • AKA Daniel
Re: Selection Filter vs. Btr Iterating
« Reply #1 on: January 30, 2011, 06:19:51 AM »
Jeff H
« Reply #2 on: January 30, 2011, 06:41:59 AM »
« Reply #3 on: January 30, 2011, 06:50:14 AM »
see this thread http://www.theswamp.org/index.php?topic=21930.0
jeeze time flies !!
 ... I think I need to take up full time coding again.
Use it or lose it, heh ?
kaefer
« Reply #4 on: January 30, 2011, 07:08:37 AM »
I guess this is the executive summary of that thread:
The less blocks in the drawing the better the advantage of the SelectionSet methodology.
Replacing blocks with Objects We're Interested In: As the quotient of OWII/Total number of objects in BTR approaches zero, iterating takes ever more time relative to a SelectionSet.
Regards
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: January 30, 2011, 07:21:48 AM »
why?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: January 30, 2011, 07:51:02 AM »
Actually, my guess is that Editor.SelectAll with a filter, iterates the database and uses AcRxObject::IsA()  to filter the set.  Selection sets should always be slightly slower than explicitly iterating, as there's a whole host of other things that happen in this process, I.e. firing off selection events, persisting the state of the set, in case a select previous needed, etc.  Plus the filter needs to be parsed through some sort of regex function.
In the case with .NET, using the 'as' keyword and a test for null is pretty efficient as its using the framework's type testing, so the object  does not need to call the underlying AcRxObject::IsA()  method.
Cheers  :-)
Jeff H
« Reply #7 on: January 30, 2011, 08:19:32 AM »
Which all the test I have done show exactly that with blocks or no blocks, unless searching for blockreferences then it is opposite Editor.SelectAll is faster
Why would this differ just BlockReferences?
Using the code below and changing to filter and add circles CenterPoint, Lines StartPoint iterating the ModelSpace BlockTableRecord was faster. For BlockReferences again SelectionFilter was faster
kaefer
« Reply #8 on: January 30, 2011, 08:26:38 AM »
why?
Good question, dan.
Iterating by GetObject with subsequent type test, that is. I did it Jeff's way; we're doing it wrong, aren't we? Testing ObjectId.ObjectClass is much faster, of  course.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: January 30, 2011, 08:30:04 AM »
True that!!
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: January 30, 2011, 08:42:01 AM »
I totally forgot about this method,  most of the code I write is 2007-2011 compatible.... :|
Jeff H
« Reply #11 on: January 30, 2011, 08:49:45 AM »
Thanks Thorsten and Daniel now it is quicker also for BlockReferences
             if (id.ObjectClass.Name == "AcDbBlockReference")
                 BlockReference dbPnt = trx.GetObject(id, OpenMode.ForRead) as BlockReference;
Jeff H
« Reply #12 on: January 30, 2011, 09:01:58 AM »
Daniel and Thorsten,
Would you recommend using something like this
if (ObjectId .ObjectClass.Name == "AcDbBlockReference")
                 // Do Whatever
if searching for a certain entity type?
Thanks again guys!
kaefer
« Reply #13 on: January 31, 2011, 04:18:39 AM »
                 // Do Whatever
I'd rather use RXClass.IsDerivedFrom, like this example (borrowed from TT):
        if( id.IsValid && id.ObjectClass.IsDerivedFrom( curveClass ) )
    static RXClass curveClass = RXObject.GetClass( typeof( Curve ) );
As Dan already mentioned, this API wasn't around from the very beginning, but only since 17.2?.
All the best
Jeff H
« Reply #14 on: February 02, 2011, 12:55:29 PM »
                 // Do Whatever
All the best
Thanks again Thorsten
