Author Topic: Search .dwg files, return which ones reference a .shx file?  (Read 4685 times)
Dommy2Hotty
« on: February 02, 2006, 09:34:25 AM »
Is there a way to search a directory of about 100 drawings and return which ones reference a .shx file?
Re: Search .dwg files, return which ones reference a .shx file?
« Reply #1 on: February 02, 2006, 10:00:18 AM »
The dot-pair for DXF 3 of the Style < iterate the style table >
just a sec ...
Dommy2Hotty
« Reply #2 on: February 02, 2006, 10:01:48 AM »
just a sec ...
« Reply #3 on: February 02, 2006, 10:03:13 AM »
This :
(mapcar '(lambda (StyleName) (cdr (assoc 3 (entget (tblobjname "STYLE" StyleName)))))
        (ai_table "STYLE" 0)
returns something like this
("ROMANS" "ISOCP" "ISOCP" "ISO3098B.shx" "ARIAL.TTF" "isocp.shx" "isocp.shx" "isocp.shx" "isocp.shx" "isocp.shx" "isocp.shx" "ARIAL.TTF" "archs.shx" "ROMAND" "ISOCP.shx" "isocp.shx" "isocp.shx" "isocp.shx" "ISOCP" "ISOCP" "ISOCP" "ISOCP" "isocp.shx" "ISOCP" "ISOCP" "ISOCP" "txt")
which you could parse ..
Dommy2Hotty
« Reply #4 on: February 02, 2006, 10:19:23 AM »
If I knew how, or what parse means...I don't have a full library of coding knowledge, just enough to get me in trouble.
Here's what I got:
("EBSIMPLX.shx" "SIMPLEX.shx" "romans.shx" "C:\\ACAD\\PRGM\\FONTS\\SIMPLEX.SHX"
"EBSIMPLX.shx" "romans.shx" "simplex.shx" "bold2.shx" "SIMPLEX.shx"
"simplex.shx" "simplex.shx" "h777lt.shx" "romans.shx"
"C:\\ACAD\\PRGM\\FONTS\\SIMPLEX.SHX" "EBSIMPLX.shx" "EBSIMPLX.shx" "h777lt.shx"
"EBSIMPLX.shx" "h777lt.shx" "WWFSLAB.shx" "C:\\ACAD\\PRGM\\FONTS\\SIMPLEX.SHX"
"EBSIMPLX.shx")
I want to know what is referencing the WWFSLAB.shx file (because we don't have it).
Jürg Menzi
  • Oberegg, Switzerland
« Reply #5 on: February 02, 2006, 10:25:19 AM »
Visit my homepage -> Free Stuff and search for 'VxGetTextStyles'...
For getting the file list use (vl-directory-files "C:\\TheDirectoryToScan" "*.dwg")
To open the dwg's use ObjectDBX
Modify my function for the document object from ObjectDBX:
(defun VxGetTextStyles (Doc / StyLst)
 (vlax-for Sty (vla-get-TextStyles Doc)
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Jürg Menzi
« Reply #6 on: February 02, 2006, 11:12:51 AM »
Written on the fly:
Now tested and finished... :-)
(defun C:ScanTextFonts ( / AcaObj CurFld DbxObj FilLst FndFlg ObjStr StyLst
                           TmpFnm)
; Notes:
;   - For A2k-A2k2 you need to register axdb15.dll by regsvr32, no need
;     to do that for A2k4+
 (setq AcaObj (vlax-get-acad-object)
       ObjStr (if (< (atof (getvar "ACADVER")) 16.0)
               "ObjectDBX.AxDbDocument"
               "ObjectDBX.AxDbDocument.16"
       Me:Fnm (cond (Me:Fnm) ("txt"))
       CurFld (MeBrowseFolder "Select a drawing Folder")
       TmpFnm (getstring T (strcat "\nFont name to search <" Me:Fnm ">: "))
       Me:Fnm (cond ((eq TmpFnm "") Me:Fnm) (TmpFnm))
  ((not CurFld))
  ((not (setq FilLst (vl-directory-files CurFld "*.dwg")))
   (alert "No drawing(s) found in this folder.")
  ((vl-catch-all-error-p
    (setq DbxObj (vl-catch-all-apply
                  'vla-GetInterfaceObject (list AcaObj ObjStr)
   (alert "Error on creating ObjectDBX object.")
  (T
   (princ (strcat "\n" (itoa (length FilLst)) " Drawings found..."))
   (princ (strcat "\nFollowing drawing(s) contain the font " Me:Fnm ":"))
   (foreach Fil (mapcar '(lambda (l) (strcat CurFld "\\" l)) FilLst)
    (if (not
          (vl-catch-all-apply 'vla-Open (list DbxObj Fil :vlax-true))
      (setq StyLst (mapcar 'cdr (MeGetTextStyles DbxObj))
            StyLst (mapcar 'strcase StyLst)
      (if (apply 'or
           (mapcar
           '(lambda (l) (wcmatch l (strcat "*" (strcase Me:Fnm) "*")))
            StyLst
       (princ (strcat "\n" (setq FndFlg Fil)))
   (if (not FndFlg)
    (princ "\nNo drawing(s) with font " Me:Fnm " found.")
   (textscr)
   (vlax-release-object DbxObj)
; == Function MeBrowseFolder
; Opens the standard folder dialog.
; Copyright:
;   ©2005 MENZI ENGINEERING GmbH, Switzerland
; Arguments [Type]:
;   Tit = Box title [STR]
; Return [Type]:
;   > Selected folder [STR]
;   > False if cancelled [BOOLEAN]
; Notes:
;   - Credits to Tony Tanzillo
(defun MeBrowseFolder (Tit / AcaObj ShlObj FldObj RetVal)
       ShlObj (vla-getInterfaceObject AcaObj "Shell.Application")
       FldObj (vlax-invoke-method ShlObj
               'BrowseForFolder (vla-get-HWND AcaObj) Tit 0
 (vlax-release-object ShlObj)
 (if FldObj
   (setq RetVal (vlax-get-property
                 (vlax-get-property FldObj 'Self)
                 'Path
   (vlax-release-object FldObj)
   RetVal
; -- Function MeGetTextStyles
; Returns a list of all text style names and her font files.
; Copyright:
;   ©2001 MENZI ENGINEERING GmbH, Switzerland
; Arguments [Type]:
;   Doc = Document object [VLA-OBJECT]
; Return [Type]:
;   > Dotted pair list '(("StyleName" . "FontFile")...) [LIST]
; Notes:
;   - None
(defun MeGetTextStyles (Doc / StyLst)
  (setq StyLst (cons
                (cons
                 (vla-get-Name Sty)
                 (vla-get-FontFile Sty)
                StyLst
 (reverse StyLst)
« Last Edit: February 03, 2006, 10:12:15 AM by Jürg Menzi »
Jürg Menzi
« Reply #7 on: February 03, 2006, 09:43:19 AM »
I've made some modifications and completions...
Peter Jamtgaard
« Reply #8 on: February 04, 2006, 05:33:22 PM »
If you pass the first function a directory like (dbx-shx "c:/acad/lisp") it will print the drawing names and the shx fonts in each file.
Peter
(defun DBX-SHX (strDirectory / lstFiles objDBXDocument)
 (if (setq lstFiles (vl-directory-files strDirectory "*.dwg"))
  (foreach strFile lstFiles
   (dbx-shx2 (strcat strDirectory "/" strFile))
(defun DBX-SHX2 (strDrawingName /  objTextStyle)
 (print strDrawingName)
 (if (not objDBXDocument)
  (setq objDBXDocument  (vla-GetInterfaceObject
                         "ObjectDBX.AxDbDocument.16"; The .16 is for 2004
 (if strDrawingName
   (vla-open objDBXDocument (findfile strDrawingName))
   (vlax-for objTextStyle
             (vla-get-textstyles
              (vla-get-activedocument
;    (print (entget (vlax-vla-object->ename objTextStyle)))
    (if (or (not (vl-filename-extension
                  (vla-get-fontfile objTextStyle)
            (= (strcase
               ".SHX"
     (print (vla-get-fontfile objTextStyle))
Jürg Menzi
« Reply #9 on: February 08, 2006, 02:56:44 PM »
Hmmmm...
Does it make sense to write and test a solution to kill time?... just brood... :?
