Author Topic: Showing Slides in a .NET Form  (Read 9252 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: November 19, 2008, 02:21:38 AM »
Step 1, register Slide.ocx on your computer.
Step 2, in VS choose Tools->Choose Toolbox Items and select the slide control ..pic 1
Step 3, add the control to a form .. pic 2
Step 4, add code
  public partial class FormSlide : Form
    public FormSlide()
      InitializeComponent();
      this.axSlide1.FileName = "b2d2d.sld"; //<<----------------------
    private void buttonClose_Click(object sender, EventArgs e)
      this.Close();
Step 5, look at pic 3
It's Alive!
  • Retired
  • AKA Daniel
Re: Showing Slides in a .NET Form
« Reply #1 on: November 19, 2008, 02:34:47 AM »
Some other classes in Slide.ocx
Glenn R
« Reply #2 on: November 19, 2008, 04:56:47 AM »
Nice find Daniel.
« Reply #3 on: November 19, 2008, 06:11:31 AM »
Thanks Daniel .. that was on my list.
MickD
« Reply #4 on: November 19, 2008, 03:40:15 PM »
Thanks Daniel, that was also on my list as well, will put it to good use.
- John Carmack
- J.R.R. Tolkien
cadpro
« Reply #5 on: January 13, 2009, 05:41:58 AM »
How do I access the width property of the slide?
Sld.Width and Sld.Height
gile
  • Marseille, France
« Reply #6 on: January 21, 2009, 03:33:35 PM »
Thanks Daniel, it seems to be very nice but I have some very newby's questions:
where do I find the slide.ocx file ?
how do I register it ?
have I to load and register it on each computer ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: January 21, 2009, 09:44:19 PM »
I found the slide.ocx here
http://discussion.autodesk.com/forums/thread.jspa?messageID=3919905&#3919905
its in the SldMgr.zip, Let me know if you have trouble getting it.
I registered mine like
regsvr32 C:\Program Files\SldMgr\Slide.ocx
I do believe it must be registered on each computer
gile
  • Marseille, France
« Reply #8 on: January 22, 2009, 01:18:52 AM »
Thank you very much Daniel.
jgr
« Reply #9 on: August 28, 2010, 10:20:17 AM »
example of how to read and show autocad slides (and slide libraries) with .Net
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: August 28, 2010, 10:44:21 AM »
Nice  8-)
« Reply #11 on: August 28, 2010, 10:18:08 PM »
the ocx is no longer available .. either that or I just can't find it
jgr
« Reply #12 on: August 29, 2010, 05:23:38 PM »
Keith, if you need the ocx, i can send it.
I tried to convert my code to C# (with a translator: Tangible Instant C# and sharpdevelop). but... Can anyone help me?. Not with private messages.
Thanks.
« Reply #13 on: August 29, 2010, 05:56:38 PM »
From an old archive ..
jgr
« Reply #14 on: August 29, 2010, 06:40:25 PM »
Nice. I do not need it but thanks.  :lol:
I do not speak English and might not have explained well
It's Alive!
  • Retired
  • AKA Daniel
« Reply #15 on: August 29, 2010, 06:44:25 PM »
You're reading it directly from the file, it's a good job!
« Reply #16 on: August 30, 2010, 11:17:33 AM »
I was thinking the same thing.
The only think left would be to take your code and move it to its own class. then it could be used in a variety of different applications.
« Reply #17 on: August 31, 2010, 03:59:46 AM »
Ok, I have taken the initiative and ported the VB code to C# and built a dll that will create a bitmap from the slide. This bitmap can be assigned to a picture control or any other object that accepts a bitmap image.
The default resolution of the bitmap is 1600x1200 but it can be set by the user as desired, since any zoom or stretch of the bitmap will cause it to look bad.
You can set the bitmap to retain the aspect ratio if desired, otherwise it will fill the bitmap to its extents causing it to be distorted if the aspect ratio isn't the same as the slide.
There are other things that could be done ... and probably will ... in the meantime, the managed code will be a better addition to the toolbox than a COM object.
Source code is included, (VB code complements of jgr)
jgr
« Reply #18 on: September 01, 2010, 12:08:08 PM »
Thank you very much.
jgr
« Reply #19 on: May 27, 2011, 11:05:36 AM »
New (C#) code for playing with slides/slide libraries
- Correctly displays slides created with Motorola 68000-family CPUs (in acad.slb: MEDIT_OT, MEDIT_OC,
MEDIT_MT, MEDIT_MC, MEDIT_CT, MEDIT_CJ,MEDIT_CC, 15W100, 14W100, 13W100, 12W100,
11W100, 10W100, 09W100, 08W100, 07W100, 06W100,05W100, 04W100, 03W100, 02W100)
- Keeps the aspect ratio.
- other code improvements and minor bug fixes
Compile before opening the form designer.
qjchen
  • Best wishes to all
« Reply #20 on: March 21, 2012, 06:36:39 AM »
Thank you, Jgr, it is a rather good program.~
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
neyton
« Reply #21 on: April 01, 2012, 08:44:06 PM »
Uns tempos atraz eu fiz um visualizador de slides em VB.NET, o fonte e o programa estão aqui:
google translate
I did some time behind a slideshow viewer in VB.NET, the source and the program are here:
http://tbn2.blogspot.com/2009/08/slideviewer-source-code.html
Visit my website: http://tbn2.blogspot.com
exmachina
« Reply #22 on: April 02, 2012, 11:37:20 AM »
google translate
Thanks for your contribution, but has many errors. Look here:
http://www.theswamp.org/index.php?topic=34954.0
neyton
« Reply #23 on: April 03, 2012, 09:53:43 AM »
o meu programa é outro, não tem nada a ver com este que você indicou
google translate:
my program is different, has nothing to do with this you indicated
see:
http://tbn2.blogspot.com.br/search?q=slideviewer
