Author Topic: CTB to XLS or TXT  (Read 4154 times)
Andrea
CTB to XLS or TXT
« on: January 20, 2005, 06:36:15 PM »
Hi all,
I'm trying to find a routine or a program to export the CTB file in Excel or TXT file.
thanks.
Keep smile...
MikePerry
CTB to XLS or TXT
« Reply #1 on: January 20, 2005, 06:50:52 PM »
Andrea
CTB to XLS or TXT
« Reply #2 on: January 21, 2005, 10:50:29 AM »
Thanks Mike,
I've downloaded and try all...
But not easy to make this work...
need
Tableprint8.exe and
TablePrintGUI.exe
to have a good functionning program.
Also the program TablePrintGUI.exe is not working if you not save the
txt file under c:\windows\temp  and call this file TEMP.TXT only !
And if I print directly the txt file, the result of printing is not
"visual accepted" (by superior)
I need more flexibilitie....
Keep smile...
CADaver
CTB to XLS or TXT
« Reply #3 on: January 21, 2005, 10:53:48 AM »
I too have been looking for something more flexible.  So far everything requires a file of some kind in ACAD's root directory.  When working at a client's site, or remote location, I rarely have write access to that directory.
