I try to do the change hereCode - Auto/Visual Lisp: [Select](defun create_dcl (fn / acadfn) (if (null(wcmatch (strcase fn) "*`.DCL")) (setq fn (strcat fn ".DCL")) ) (if (not (findfile (strcat (getvar "roamablerootprefix") fn))) ;; create dcl file (progn (setq fn (strcat (getvar "roamablerootprefix") fn) fn (open fn "w") ) but is not working. Can any one help me to create the dcl file in C:\Users\Admin\AppData\Local\Temp Thanks
Hi ronjonp. I can not understand your answer!!! ...
Hi ronjonp . I replace the part in the code , run the code without errors but when i write CFL to start the lisp nothing happened . Any idea?Thanks
