I'm using LISP within the block editor to setup several parameters and actions.
How can I get a selection set for the BACTIONTOOL to use?
(command "bparameter" "point" pt1
(polar pt1
1.5708 12.0) "1") (command "bparameter" "rotation" (setq pt2
(polar pt1
3.66571 7.19356561)) (polar pt2
0.0 4.0) 0.0 pt2
"1") (command "_Bactiontool" "_move" (car (entsel "\nSelect MOVE parameter: ")) (ssget)); Will need to select ROTATION parameter also. (command "_Bactiontool" "_rotation" (car (entsel "\nSelect ROTATION parameter: ")) (ssget)); Will need to select MOVE parameter also.
