Author Topic: selection set "by length"  (Read 7205 times)
  • Custom Title
« on: February 07, 2005, 01:27:40 PM »
Any way to speed up this process? So far I've tried these three variations.
;;; ============= number 1 ====================
(defun ss-by-length (lt / get-lgth ss ssf cntr ent lgth)
  ;; return a sset that contains all the LINES that are
  ;; greater than length (lt)
  (defun get-lgth (ent)
    (distance
      (cdr (assoc 10 (entget ent)))
      (cdr (assoc 11 (entget ent)))
  (gc)
  (setq ss (ssget "X" '((0 . "LINE")))
        ssf (ssadd)
        cntr 0
  (if (> (sslength ss) 0)
    (repeat (1- (sslength ss))
            (setq ent (ssname ss cntr)
                  lgth (get-lgth ent)
            (if (> lgth lt)(setq ssf (ssadd ent ssf)))
            (setq cntr (1+ cntr))
  ssf
;;; ============= number 2 ====================
    (distance
  (gc)
        ssf (ssadd)
        cntr 0
    (while (setq ent (ssname ss cntr))
           (setq lgth (get-lgth ent))
  ssf
;;; ============= number 3 ====================
    (distance
  (gc)
        cntr 0
                  lgth (get-lgth ent)
            (if (> lgth lt)(setq ss (ssdel ent ss)))
  ss
« Reply #1 on: February 07, 2005, 02:05:16 PM »
What if you rethink the idea?
For example, I'm a big believer in flexible functions. What if you had a function that was essentially a "remove ename from selection set if predicate function (that takes an entity name as the sole argument) is true?" kind of thing.
Not optimized, but ...
(defun SSRemoveIf ( QuotedFunction ss / i ename )
        (   (eq 'pickset (type ss))
                    (apply QuotedFunction
                        (list
                            (setq ename
                                (ssname ss (setq i (1- i)))
                    (ssdel ename ss)
            (if (< 0 (sslength ss)) ss)
Then you could call it like ...
(SSRemoveIf
   '(lambda (ename)
        (<  (vla-get-length
                (vlax-ename->vla-object ename)
            10 ;; remove all lines less than 10 units long
    (ssget "x" '((0 . "line")))
This is over simplified, you would probably need to employ robust error trapping; I wanted to keep it simple for idea clarity.
Just a thought.
Edit: Revised SSRemoveIf.
« Reply #2 on: February 07, 2005, 03:05:37 PM »
How does this one fair?
I did not test it.
(defun ss-by-length (lt / ss ename elst)
  (and
    (setq ss (ssget "X" '((0 . "LINE"))))
    (while (setq ename (ssname ss (setq i (1- i))))
      (setq elst (entget ename))
      (if (< (distance (cdr(assoc 10 elst))(cdr(assoc 11 elst))) lt)
        (ssdel ename ss))
  ss
EDIT: I think I fixed it... :?
« Reply #3 on: February 07, 2005, 06:31:41 PM »
Hey CAB -- it's not a good idea to iterate thru a selection set in a forward direction if you are modifying it (adding or removing members).
Also, I think you missed some cdr statements (does run fast when fixed up).
Cheers. :)
« Reply #4 on: February 07, 2005, 07:05:57 PM »
Oooops, :oops:
Sorry about that. I did not think about that. The pointer would get lost.
That's what happens when you don't test your work. I can't write error free
code on the fly like you and Stig can. :)
« Reply #5 on: February 07, 2005, 08:08:03 PM »
Quote from: CAB
I can't write error free code on the fly like you and Stig can. :)
I think you have me confused with someone else CAB -- I araely wrtie errro fere cdoe no teh fyl. :D
spacebuffalo
manipulating the ss by line length
« Reply #6 on: February 07, 2005, 08:13:42 PM »
the ss in the while loop is different than the returned ss...
« Reply #7 on: February 07, 2005, 08:30:54 PM »
I posted the repaired code, so Mark try it again. 8)
« Reply #8 on: February 07, 2005, 08:57:49 PM »
:Oo:
I understood every word of that sentence. (Is that sad?! Do i really spell that bad. Do i really spell like "T I Double 'Grr'" speaks?)
:P
  • Custom Title
« Reply #9 on: February 08, 2005, 07:00:15 AM »
- CAB
that surely beats mine in a speed test. :D
- MP
That is truly ingenious! I would have never thought of that. I'm still looking at how I might  "optimized" that code.
Thanks for all the input guys.
whdjr
« Reply #10 on: February 08, 2005, 08:11:11 AM »
MP,
How do you even think like that? :D
That is too cool!
« Reply #11 on: February 08, 2005, 08:36:38 AM »
Quote from: whdjr
MP,
That is too cool!
"How, can you not think like that?" said MP the Lisp Master :)
It amazes me too, I think these folks have internalized the language and with
there creative talent it just flows out.
« Reply #12 on: February 08, 2005, 10:45:43 AM »
Guys, it's not all that clever -- it's just an adaptation of functions we already have, like vl-remove-if.
« Reply #13 on: February 08, 2005, 12:18:37 PM »
Some quick notes on performance.
This code --
(SSRemoveIf
   '(lambda (ename)
        (<  (vla-get-length
Is fine if the code will be executed once, but if the code will be executed multiple times, say in a process loop, better performance will be realized by committing the functionality to a formal function. This would remove the overhead associated with the creation of the temporary function for each iteration.
Example --
(defun Foo (ename)
    (<  (vla-get-length
(repeat n
        (   (setq ss
                (SSRemoveIf
                   'Foo  ;; note, quoted function
            ;;  now do something with the selection set ...
Still better performance can be realized if we remove the need for the function to be quoted:
(defun SSRemoveIf ( UnquotedFunction ss / i ename )
                    (UnquotedFunction
                        (setq ename
                    (ssdel ename ss)
Now call it using an unquoted function --
(SSRemoveIf
    Foo ;; note, unquoted function call
Finally1, if you are writing an application that must run as fast as possible, using generic functions / structures like above are probably not the way to go. In that case I would likely hand roll each function specifically for each task.
Finally2, also note that there are differences between activex calls and dxf equivalents -- sometimes activex wins, sometimes it doesn't. You may have to do some benching.
Enjoy. :)
  • Custom Title
« Reply #14 on: February 08, 2005, 12:44:09 PM »
Quote from: MP
Enjoy. :)
Oh .......... I am.  :D
Many thanks there MP.
« Reply #15 on: February 08, 2005, 02:03:58 PM »
My pleasure Mark. :wink:
« Reply #16 on: February 09, 2005, 10:10:02 PM »
Speaking of optimizing, benchmarking ... thought you might find this illuminating Mark ...
Using this benchmarking utility ...
(defun c:Test
        GetEnameDistance
        GetEnameLength
        GetObjectLength
        ename
        object
    (defun GetEnameDistance ( ename / data )
        (distance
            (cdr (assoc 10 (setq data (entget ename))))
            (cdr (assoc 11 data))
    (defun GetEnameLength ( ename )
        (vlax-get-property
            'Length
    (defun GetObjectLength ( object )
        (vlax-get-property
            object
            'Length
    (setvar "cmdecho" 0)
    (command ".line" '(0 0) '(10 10) "")
    (setq object
            (setq ename (entlast))
    (Benchmark
            (GetEnameDistance ename)
            (GetEnameLength ename)
            (GetObjectLength object)
    (vl-catch-all-apply
       '(lambda ()
            (entdel ename)
(c:Test)
Output:
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (GETOBJECTLENGTH OBJECT).....1687 / 1.63 <fastest>
    (GETENAMEDISTANCE ENAME).....1985 / 1.39
    (GETENAMELENGTH ENAME).......2750 / 1.00 <slowest>
  • Custom Title
« Reply #17 on: February 10, 2005, 08:08:55 AM »
Now that is cool !!
I'm surprised that 'GetEnameDistance' was slower than 'GetObjectLength'.
SMadsen
« Reply #18 on: February 10, 2005, 08:30:33 AM »
Got another result:
   (GETENAMEDISTANCE ENAME).....1234 / 1.82 <fastest>
    (GETOBJECTLENGTH OBJECT).....1390 / 1.62
    (GETENAMELENGTH ENAME).......2250 / 1.00 <slowest>
SMadsen
« Reply #19 on: February 10, 2005, 08:41:47 AM »
Here's an interesting observation. Given the function below, passing an object to it is slower than passing an ename:
   (defun GetCurveLength ( object )
      (vlax-curve-getDistAtPoint
        object
        (vlax-curve-getEndPoint object)
Object:
    (GETENAMEDISTANCE ENAME).....1219 / 1.99 <fastest>
    (GETOBJECTLENGTH OBJECT).....1484 / 1.63
    (GETCURVELENGTH OBJECT)......2047 / 1.18
    (GETENAMELENGTH ENAME).......2422 / 1 <slowest>
Ename:
    (GETCURVELENGTH ENAME).......1235 / 2.19 <fastest>
    (GETENAMEDISTANCE ENAME).....1500 / 1.8
    (GETOBJECTLENGTH OBJECT).....1781 / 1.52
    (GETENAMELENGTH ENAME).......2703 / 1 <slowest>
« Reply #20 on: February 10, 2005, 08:48:44 AM »
My results. Ran it twice.
   (GETENAMEDISTANCE ENAME).....1222 / 1.57 <fastest>
    (GETOBJECTLENGTH OBJECT).....1322 / 1.45
    (GETENAMELENGTH ENAME).......1913 / 1.00 <slowest>
    (GETENAMEDISTANCE ENAME).....1112 / 1.65 <fastest>
    (GETOBJECTLENGTH OBJECT).....1271 / 1.44
    (GETENAMELENGTH ENAME).......1833 / 1.00 <slowest>
PS.  I think Michael's computer has a vla bias. :)
  • Custom Title
« Reply #21 on: February 10, 2005, 09:32:21 AM »
my results.
:: pasted 'test' strait into acad
    (GETOBJECTLENGTH OBJECT).....1375 / 1.66 <fastest>
    (GETENAMEDISTANCE ENAME).....1766 / 1.29
    (GETENAMELENGTH ENAME).......2281 / 1.00 <slowest>
:: from within the vlide/vlisp console
Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s):
    (GETENAMEDISTANCE ENAME).....1062 / 1.97 <fastest>
    (GETOBJECTLENGTH OBJECT).....1281 / 1.63
    (GETENAMELENGTH ENAME).......2094 / 1.00 <slowest>
« Reply #22 on: February 10, 2005, 10:49:35 AM »
Quick note --
I was running under AutoCAD 2004 and killed all other apps as well as my internet connection.
Also --
Quote from: Disclaimer
   ;;  Notes:
    ;;      I make no claims that this is definitive benchmarking. I
    ;;      wrote this utility for my own purposes and thought I'd
    ;;      share it. Many considerations go into evaluating the
    ;;      performance or suitability of an algorythm for a given
    ;;      task. Raw performance as profiled herein is just one.
    ;;      Please note that background dramatically affect results.
In other words, it's a guide, an indicator of performance, but as written I don't think it's a definitive work for benchmarking. Take the results with a grain a salt, switch the order of the statements being evaluated, perform several runs etc.
<gotto go, sorry to be so brief>
