Author Topic: Using ssget "X" to Get block name if block contain more then 20 lines of attribu  (Read 5117 times)
jaydee
Hi.
At the moment i got this lisp that work well with block attributes using (ssget "X" '(0 . "insert")(2 . "blockname"))
The only issue is that i have to provide the block name (sheet title attributes) .
every so often someone decided to rename this block to suit project.
therefore im thinking is there a way to do this without providing a blockname in my lisp.
finding a tagname wont work, because im not confident that the tagname is unigue. therefore i still need the blockname.
What i would like to achieve is, do a ssget "x" on layout
if a block with more then 20 line of attdef, (im very sure theres only 1 block with that many tag)
then return the block name.
Thankyou
The ssget function can only search the drawing database for primary entities, not subentities such as attributes/vertices.
Therefore, you have two options: the first would be to iterate through all attributed blocks in the drawing, then single out those that have more than 20 attributes:
(defun GetBlocksWithMoreThan20Attribs ( / at en i ss )
  (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i)))
            at 0
      (while (eq "ATTRIB" (cdr (assoc 0 (entget (setq en (entnext en))))))
        (setq at (1+ at))
      (if (< at 20)
        (ssdel (cdr (assoc 330 (entget en))) ss)
  ss
The second would be to iterate through the block table, and collect the names of blocks with more than 20 attribute definitions, then create a selection set of these blocks.
(defun GetBlocksWithMoreThan20AttDefs ( / at bd be bl nm )
  (while (setq bd (tblnext "BLOCK" (null bd)))
    (if (= 2 (logand 2 (cdr (assoc 70 bd))))
        (setq at 0
              nm (cdr (assoc 2 bd))
              be (tblobjname "BLOCK" nm)
        (while (setq be (entnext be))
          (if (eq "ATTDEF" (cdr (assoc 0 (entget be))))
            (setq at (1+ at))
        (if (<= 20 at)
          (setq bl (cons "," (cons nm bl)))
  (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (apply 'strcat (cdr bl)))))
The second method will fail however if attributes have been added to the block outside of the block definition, but this is an unlikely case.
jaydee
Thankyou Lee Mac.
These codes are very valuable to me.
Please explain
"if attributes have been added to the block outside of the block definition"
Its my shout. cheers
Please explain
When entmake'ing a Block Reference (Insert), attributes which do not belong to the Block Definition can be programmatically added to the Insert entity using entmake.
