Author Topic: Updating multiple block definitions  (Read 1898 times)
ELOQUINTET
« on: April 29, 2008, 11:27:23 AM »
Hey guys,
I've created many blocks in a drawings and have nested those blocks inside of assemblies. Now I found out I need to add another attribute to them. I updated the block but the previous insertions did not update. Take a look at the attached drawing. I need to update the top 2 blocks to include the X attribute like the bottom one. Maybe I'm just having a brain fart this morning but how can I update the existing blocks?
VovKa
  • Ukraine
Re: Updating multiple block definitions
« Reply #1 on: April 29, 2008, 12:17:43 PM »
_battman
choose block name then press 'Sync'
ELOQUINTET
« Reply #2 on: April 29, 2008, 12:45:27 PM »
I don't think I worded it right. All of the blocks contain the attribute but what I'm really after is that I want the attribute to be visible which it is not unless I reinsert it. I think I need to reinsert all the blocks where they are now. Does that make anymore sense?
« Reply #3 on: April 29, 2008, 12:48:05 PM »
Dan,
What you are looking for is ATTSYNC.
ELOQUINTET
« Reply #4 on: April 29, 2008, 12:55:12 PM »
ron when i run attsync and select the new (reinserted) block that shows the attribute then select the existing block with the same name i do not see the added attribute?
« Reply #5 on: April 29, 2008, 01:17:44 PM »
Don't know...it worked here for me :?
VovKa
  • Ukraine
« Reply #6 on: April 29, 2008, 01:18:08 PM »
tested on acad 2004
both methods (attsync or via battman) work well on 'update block definitions.dwg'
do a 'regen'
Bob Wahr
« Reply #7 on: April 29, 2008, 01:31:00 PM »
Do the new attributes that you aren't seeing have values?
ELOQUINTET
« Reply #8 on: April 29, 2008, 02:07:04 PM »
Hmmm interesting. I am using 2002 so I went over and tested it on our test machine that has 2007 on it and it works fine. I just need to do a regenall to get the attribute to display in the assembly. I guess it must be another wonderful feature of 2002  :pissed:
