Author Topic: AutoCAD 2011 Mechanical selection crash  (Read 2883 times)
jlatimer11
  • Mosquito
« on: January 19, 2011, 01:21:50 PM »
VB.NET 2008 Express
.net Framework 3.5
Windows 7 Professional
Not sure why this is happening. Any type of code requiring someone to choose an object crashes upon run every time. I've looked up the error code (e0434f4dh) and it seems to point to a .net Framework issue.
The issue with this is that I'm running Windows 7, so that means I can't just uninstall and re-install .net Framework on a whim since it is installed at OS setup. I've re-installed AutoCAD from scratch and I've tried the .net cleanup tool, and both have not worked.
Here is the code I've been attempting to use:
Dim myDB As DatabaseServices.Database
Dim myDWG As ApplicationServices.Document
Dim myEd As EditorInput.Editor
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim MySelObj As DatabaseServices.DBObject
Dim myPNER As EditorInput.PromptNestedEntityResult
Dim myAttRef As DatabaseServices.AttributeReference
myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
myDB = myDWG.Database
myEd = myDWG.Editor
myPNER = myEd.GetNestedEntity("Select an attribute: ")
If IsNothing(myPNER.ObjectId) = False Then
myTransMan = myDWG.TransactionManager
myTrans = myTransMan.StartTransaction
MySelObj = myPNER.ObjectId.GetObject(DatabaseServices.OpenMode.ForRead)
If TypeOf MySelObj Is DatabaseServices.AttributeReference Then
myAttRef = MySelObj
MsgBox(myAttRef.Tag & " = " & myAttRef.TextString)
Else
MsgBox("You didn't select an Attribute." & vbCr & _
"You selected a" & vbCr & MySelObj.ToString.ToUpper)
End If
myTrans.Dispose()
myTransMan.Dispose()
End If
If I comment out the 'myPNER' line, the code does nothing, but AutoCAD does not crash.
kaefer
Re: AutoCAD 2011 Mechanical selection crash
« Reply #1 on: January 19, 2011, 05:09:10 PM »
By any chance, that wasn't "Unhandled e0434f4dh exception" or something?  Look's more like an address...
- you have no Try Catch block on your own, which could inform you about exceptions caught.
- you haven't produced an error report (dmpuserinfo.xml in your temp dir might contain more info)
- looking at your code, a few thing strike me as non-standard:
The customary way to check for success of ed.GetXXX() methods is by PromptStatus.
If (myPNER.Status = PromptStatus.OK)  Then
myTrans.Dispose()
It is considered good manners to commit as well, and wrap the scope with Try/Finally.
Try
    myTrans.Commit()
Finally
    myTrans.Dispose()
Why would you want to do that?
Glenn R
« Reply #2 on: January 19, 2011, 05:22:38 PM »
You should never be calling Dispose() on the TransactionManager. You didn't create it, so leave it alone.
Glenn R
« Reply #3 on: January 19, 2011, 05:25:14 PM »
Also, as kaefer mentioned, you should be calling Commit() on the transaction you created and started, otherwise a rollback will be initiated, which can be expensive as well as undesireable, depending on what you're doing.
« Reply #4 on: January 19, 2011, 06:53:11 PM »
James, Welcome to the Swamp.
Also;
To save your sanity later,
get into the habit of using Option Explicit and Option Strict with your code.
Type safety is something you will want to take control of sooner or later and it may as well be sooner ... instead of relying on the VB IDE to change your code behind the scenes at compile time to force it to conform to what it assumes are your intentions.
Regards
jlatimer11
  • Mosquito
« Reply #5 on: January 19, 2011, 07:21:20 PM »
I apologize for the crude code, but I'm using a guide book since I'm very unfamiliar with VB.NET.
The error was definitely 'Unhandled e0434f4dh exception', which I found out was because my source files were on a network share. Once I took them off the crashes stopped.
Thanks for the info on transactions. They are the one thing going from VBA to VB.NET that  I can't wrap my head around yet.  :-)
« Reply #6 on: January 19, 2011, 08:54:45 PM »
James,
yes, I recognised the code style from the book. :)
