Author Topic: On App Activate Event  (Read 6546 times)
ML
« on: October 16, 2007, 12:39:42 PM »
Hi
On the App Activate Event Procedure, I am trying to run the below code however, the code is not working on App Activate; instead it is working when I minimize and amximize the App Window.
Am I using the wrong Event oe Method here?
May be I should be using the macro
Sub acadstartup()
 'code here
Instead????
Thanks Mark
Private Sub AutoCAD_AppActivate()
Dim Preferences As AcadPreferences
Dim CurrMenuFile As String
Set Preferences = ThisDrawing.Application.Preferences
CurrMenuFile = Preferences.Files.MenuFile
Select Case CurrMenuFile
 Case Is = "Land"
  ThisDrawing.SendCommand "wscurrent" & vbCr & "Land Destop Complete" & vbCr
 Case Else
  ThisDrawing.SendCommand "wscurrent" & vbCr & "Map Classic" & vbCr
End Select
quamper
Re: On App Activate Event
« Reply #1 on: October 16, 2007, 02:02:25 PM »
Are you trying to do something on activation or something else like on loading? Activation is what you are talking about.. if the program is in the background and then you select it, or unminimizing you've just "activated" the application.
See this msdn article http://msdn2.microsoft.com/en-us/library/dyz95fhy(VS.80).aspx
ML
« Reply #2 on: October 16, 2007, 02:03:53 PM »
Yes
I was referring to on startup
ML
« Reply #3 on: October 16, 2007, 02:17:36 PM »
OK
I have an acadstartup macro in my acad.dvb file
with the above (first post) code in it.
I am initializing VBA by having acvba.arx inside my acad.rx file.
I also have my acad.dvb file in Startup Suite.
Also, here is proof that VBA is initializing and running my startup macro:
After I start ACAD, I hit F2 and get this:
However, my workspace is not physically switching to Map Classic
Any ideas?????
Initializing VBA System...
Loading VBA startup file...wscurrent
Map Classic
Guest
« Reply #4 on: October 16, 2007, 02:40:56 PM »
Instead of SendCommand, try this...
ThisDrawing.SetVariable("wscurrent", "Map Classic")
...since the Work Space is a system variable.
I've never really had much luck with SendCommand.   :-(
ML
« Reply #5 on: October 16, 2007, 02:44:39 PM »
Matt
That is a great idea!
You are right, it is a system variable DUH :)
That would be much better then the send command.
The send command certainly does have some use but I try to avoid it when possible.
The interesting thing is that the macro works fine if I run it from within ACAD but not on startup
I think you just touched on something; I don't think VBA likes the idea of sending commands to the command line on startup
Let's see
Guest
« Reply #6 on: October 16, 2007, 02:46:49 PM »
Good luck!
ML
« Reply #7 on: October 16, 2007, 02:55:40 PM »
THanks Matt!
The only problem is that this syntax
is incorrect
So, first I am trying to work that out
Guest
« Reply #8 on: October 16, 2007, 02:57:52 PM »
THanks Matt!
is incorrect
Yeah, you're right.  I was messing around with it and had MsgBox in front of it.  Just remove the parentheseseseses and you should be all set.
ML
« Reply #9 on: October 16, 2007, 02:59:39 PM »
Nope, that doesn't work either LOL
Don't you love it, it is always the small things :)
It probably has to be setvariable wscurrent = etc etc
ML
« Reply #10 on: October 16, 2007, 03:14:36 PM »
Matt
The help screen says
Dim strData As String
 sysVarName = "DCTCUST"
 strData = "My Custom Dictionary"
 sysVarData = strData        ' String data
 ThisDrawing.SetVariable sysVarName, sysVarData
This tells me
I need
ThisDrawing.SetVariable("wscurrent", Map Classic)
but this method is not working????????
I never have a problem when I use getvariable
ML
« Reply #11 on: October 16, 2007, 03:17:36 PM »
Actually
I take that back; according to the help, it should be
ThisDrawing.SetVariable ("wscurrent", "Map Classic")
But I got it
It is this:
ThisDrawing.SetVariable "wscurrent", "Map Classic"
Now, I can get back to the original problem :)
ML
« Reply #12 on: October 16, 2007, 03:23:04 PM »
I am having a post with myself here :lol:
The help screen was correct the whole time; it is my brain that is not right  :lol: :)
Ok, well that did it!
No sendcommand  in The acadstartup
So, in my Acadstartup macro
I have:
Sub Acadstartup()
Set AutoCAD = ThisDrawing.Application
 Case Is = "Land"
   ThisDrawing.SetVariable "wscurrent", "Land Destop Complete"
 Case Else
End Select
All seems to be working well
Thanks for the clue Matt!
Guest
« Reply #13 on: October 16, 2007, 03:30:14 PM »
Is this a typo??
Should there be a K in there??!?
ML
« Reply #14 on: October 16, 2007, 03:33:39 PM »
Yes, it is thank you :)
That's all I need is to spend another 30 minutes figuring that one out LOL
