Author Topic: Replace item in list with new item  (Read 7699 times)
daron
Re: Replace item in list with new item
« Reply #15 on: February 13, 2008, 02:11:12 PM »
Hmm. First off, I guess I don't understand why you're using eval or what eval is doing here? I set up a list like: (setq llist '(1 2 3 4 5)) and ran your function and it crashed. On deeper inspection, the eval crashed right out of the gate. What should I be supplying here?
« Reply #16 on: February 13, 2008, 02:40:15 PM »
Im using eval because...read up on ``set''.
Did you read the comments?
(list-pop 'llist)
daron
« Reply #17 on: February 13, 2008, 03:09:51 PM »
Yes I read the comments. I think my mind is turning to mush. Let me show you what I've been trying to accomplish and see if you can lead me to understanding what I'm not getting.
(defun pop (masterList pos)
     (setq inc -1)
     (set 'tval (nth pos masterList))
     (setq old       (mapcar '(lambda (x)
    (setq inc (1+ inc))
    (cons inc x)
      masterList
   new       (subst nil (assoc pos old) old)
   masterList (vl-remove 'nil (append (mapcar 'cdr new)))
     (list tval masterList)
After forgetting what eval and set are really doing for you, I wasn't getting the return value properly. What this is trying to do is improve on your initial idea. It would be cool to have the ability to remove an item from anywhere within the list and alter the list like you've done. Somewhere in there I need to add an eval. I'm just not sure where now. As for why eval crashed on me, I figured it out.
« Reply #18 on: February 13, 2008, 05:01:12 PM »
Sorry man but your code is a bit confusing.
Here is a quick and dirty version for removing position using mapcar (I think it might be easier with a loop but none the less.).
(defun positional-list-pop (lst pos / ~tval cntr)
  (setq ~tval (eval lst)
        cntr -1)
  (set lst
       (mapcar
         '(lambda ( x )
            (setq cntr (1+ cntr))
            (if (not (eq cntr pos)) x))
         ~tval
  pos
(setq llist '(1 2 3 4 2 2 5))
(positional-list-pop 'llist 2)
« Reply #19 on: February 13, 2008, 05:10:01 PM »
That just places a 'nil' in place of the value.  I don't think you can use 'mapcar' for this, at least I haven't seen a way and can't think of one without using a 'vl-remove....' something.
« Reply #20 on: February 13, 2008, 05:40:01 PM »
yep.
I was thinking a loop would be better.
Let me think about it some more.
VovKa
  • Ukraine
« Reply #21 on: February 13, 2008, 05:47:15 PM »
(defun RemoveNth (InList Position / OutList)
  (while (> Position 0)
    (setq OutList  (cons (car InList) OutList)
  InList   (cdr InList)
  Position (1- Position)
  (append (reverse OutList) (cdr InList))
« Reply #22 on: February 13, 2008, 05:51:34 PM »
VovKa is using a loop like what i would have done. Although, that procedure does not redefine the orig variable, that is just a small fix.
Seeing as i beet to the punch; We can take a play from Matt Stachoni's book and do this as well?
        ~tval
        (apply
          'append
          (subst nil (list (nth pos ~tval)) (mapcar 'list ~tval))))
  (set lst ~tval)
  pos
VovKa
  • Ukraine
« Reply #23 on: February 13, 2008, 06:10:14 PM »
(setq llist '(3 1 2 3 4 2 2))
llist would be '(3 1 3 4), and that is wrong. subst is not good for this
« Reply #24 on: February 13, 2008, 06:16:36 PM »
Good catch VovKa.
Quote from: Acad help for 'subst'
Searches a list for an old item and returns a copy of the list with a new item substituted in place of every occurrence of the old item
Never read this before.
« Reply #25 on: February 13, 2008, 06:34:47 PM »
Ah shoot! ...Fine, be that way! Not a loop in there!
(Have fun with a big list *ptttht!*)
cntr -1
~tval
      (apply
'append
(subst nil
       (list nil)
       (mapcar 'list
       (mapcar
'(lambda (x)
      x
~tval
  (set lst ~tval)
  pos
Preforming this operation without using a loop is getting ridiculous! What are we on four n{fx4} now?
VovKa
  • Ukraine
« Reply #26 on: February 13, 2008, 06:39:53 PM »
no loops, no recursions, no speed :)
(defun RemoveNth3 (InList Position /)
  ((lambda (rest)
     (append (reverse
       (cdr
(vl-member-if
   (function (lambda (e) (= (setq Position (1+ Position)) (length rest)))
   (reverse InList)
     rest
    (cdr (vl-member-if
   (function (lambda (e) (< (setq Position (1- Position)) 0)))
   InList
daron
« Reply #27 on: February 13, 2008, 06:43:30 PM »
well, this has been a fun challenge. I'll have to check these things out later.
VovKa
  • Ukraine
« Reply #28 on: February 13, 2008, 06:49:39 PM »
and the easiest one
(defun RemoveNth4 (InList Position /)
  (vl-remove-if
    (function (lambda (e) (= (setq Position (1- Position)) -1)))
    InList
« Reply #29 on: February 13, 2008, 06:52:52 PM »
yeah, but he wanted a lisp pop procedure AND use mapcar. :P
