Author Topic: ObjectOverrule Open  (Read 1694 times)
cincir
ObjectOverrule Open
« on: May 08, 2015, 11:02:03 AM »
Hi everyone,
I am overriding Open method of ObjectOverrule. When I open the object by transaction and ForRead , Open method of ObjectOverrule is not called. If I open the object ForWrite it is called.
I also tried to open the object directly by ObjectId.Open() then regardless of the OpenMode Open method of the ObjectOverrule is invoked.
Anybody knows why?
Cheers.
MexicanCustard
Re: ObjectOverrule Open
« Reply #1 on: May 11, 2015, 07:46:11 AM »
I get an event whether its read or write.
What version of AutoCAD?  What's the code look like?  How are you implementing your overrule?  How are you opening the object, ObjectId.Open, Transaction.Open, TransactionManager.Open.  If you'll post some code we can try to replicate your problem.
