How can this routine be modified to prompt for either a real number or by selecting an entity for both the upper & lower elevations?
.....ie, "Enter a starting elevation: <Enter to pick text>"
(defun c:Slo (/ ocmd ent1 uelev lelev lng1 txts ang1)
(command "_.undo" "_end")
(command "_.undo" "_group")
(setq clay (getvar "clayer"))
(setq ocmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq ent1 (entsel "\nSelect upper elevation: "))
(if ent1
(setq ent1 (makex (car ent1)))
(setq uelev (getx ent1 'TextString))
(setq ent1 (entsel "\nSelect lower elevation: "))
(if ent1
(setq lelev (getx ent1 'TextString))
(setvar "osmode" 617)
;;;;;;;;;;;(command "-layer" "s" "dra-breakline" "")
(prompt "\nEnter point(s): ")
(command "_.pline")
(while (> (getvar "cmdactive") 0)
(command pause)
(setq ent1 (makex (entlast)))
(setq lng1 (getx ent1 'Length))
(if (and uelev lelev lng1)
(setq txts (* (/ (- (atof uelev) (atof lelev)) lng1) 100))
(setq ang1
(rtd
(angle
(getpoint "\nSelect slope label angle (going left to right). ")
(getpoint "\nSelect end point of angle. ")
(prompt "\nSelect insertion point of slope text: ")
(if (> (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))) 0)
(command "_text" "j" "bc" pause ang1 (strcat(rtos txts 2 2)"%"))
(command "_text" "j" "bc" pause "" ang1 (strcat(rtos txts 2 2)"%"))
(command "-layer" "s" clay "")
(setvar "cmdecho" ocmd)
