Author Topic: see the variables  (Read 3736 times)
Andrea
see the variables
« on: February 24, 2005, 10:21:52 PM »
ok there is a good one...
when i open a new or existing drawing, and load some lisp files...
is there any way to see all active variables ?
eg:
if I load a lisp and in this lisp you have this code..
(setq var1 (getvar "textsizse")
        var2 (getvar "dwgname")
and the var1 and/or var2 is not set to nil after or before loading the file...
so i would like to know how many variables not set to nil can i found.
something like (PRINT ALLVARS)
var1 = 1
var2 = "drawing1.dwg"
etc...
don't know if i'm clear... :oops:
Keep smile...
see the variables
« Reply #1 on: February 25, 2005, 01:04:01 AM »
Atoms16.vlx (compiled w/AutoCAD 2004) is gettin' a bit long in the tooth but it may provide the kind of information you're looking for.
Failing  the above it's a relatively simple matter to walk through the atoms-family and examine each symbol: is it an int, a real, a list, a string ... (be gentle I wrote this very quickly):
(defun FindSymbols
    ;;  FindSymbols © 2005 Michael Puckett · All Rights Reserved
    ;;  Version  ·  1.0 2005/02/24 MP Original code.
    ;;              1.1 2005/02/25 MP Distilled / Recoded.
    ;;  About    ·  FindSymbols is an atoms-family scanner that
    ;;              allows one to scan for specific data types c/w
    ;;              with include and exclude spec ability.
    ;;  Written  ·  Quick and dirty for www.theswamp.org and friends.
    ;;  Contact  ·  cadlabs@gmail.com
    ;;  examples
    ;;      (progn
    ;;          (mapcar 'print
    ;;              (FindSymbols
    ;;                 '(int real)      ;; find numeric values
    ;;                  "*"             ;; include everything
    ;;                  "vl*,ac*"       ;; exclude vl*,ac*
    ;;          (princ)
    ;;      (progn
    ;;          (mapcar 'print
    ;;              (FindSymbols
    ;;                 '(str)           ;; find string values
    ;;                  ""              ;; exclude nothing
    ;;          (princ)
    ;;      (progn
    ;;          (mapcar 'print
    ;;              (FindSymbols
    ;;                      safearray   ;;
    ;;                      variant     ;; find activex values
    ;;                      vla-object  ;;
    ;;          (princ)
    ;;  data returned
    ;;          (A INT 1)
    ;;          (B INT 2)
    ;;          (C INT 3)
    ;;          (PI REAL 3.14159)
    (   typeList
        includeFilter
        excludeFilter
        GetSymbolProperties
    (defun GetSymbolProperties ( symbol / value )
        (list
            symbol
            (strcase (vl-symbol-name symbol))
            (type (setq value (vl-symbol-value symbol)))
            value
    (if (null typeList)
        (setq typeList
           '(   ename
                exrxsubr
                file
                int
                list
                pagetb
                pickset
                real
                safearray
                str
                subr
                sym
                usubr
                variant
                vla-object
    (setq includeFilter
        (if (/= 'str (type includeFilter))
            (strcase includeFilter)
    (setq excludeFilter
        (if (/= 'str (type excludeFilter))
            (strcase excludeFilter)
    (mapcar
       '(lambda (x) (list (car x) (caddr x) (cadddr x)))
        (vl-sort
            (vl-remove-if 'null
                (mapcar
                   '(lambda ( properties / name )
                        (if (member (caddr properties) typeList)
                            (if (wcmatch
                                    (setq name (cadr properties))
                                    includeFilter
                                (if (not
                                        (wcmatch
                                            name
                                            excludeFilter
                                    properties
                    (mapcar 'GetSymbolProperties
                        (atoms-family 0)
           '(lambda (a b) (< (cadr a) (cadr b)))
I've really got to get a life.
Edit 1: Revised code.
Russ
see the variables
« Reply #2 on: February 25, 2005, 08:57:47 AM »
Type LSP at the command prompt. Hope this helps.
Andrea
see the variables
« Reply #3 on: February 25, 2005, 09:46:37 AM »
Quote from: MP
<Long quote back deleted>
Thanks...but i can't go to the link...
ask me for a login and password...
also...i got an error when tring the code...
Keep smile...
whdjr
see the variables
« Reply #4 on: February 25, 2005, 10:32:56 AM »
The login username and password is the same one you use for theSwamp. :shock:
see the variables
« Reply #5 on: February 25, 2005, 11:43:17 AM »
Quote from: Andrea
What whdjr said above.
Also, how are you using FindSymbols, it works for me at work and home, AutoCAD 2002 / 2004 respectively.
Try this --
(progn (mapcar 'print (FindSymbols '(int real) "*" "vl*,ac*")) (princ))
What happens?
Andrea
see the variables
« Reply #6 on: February 27, 2005, 06:12:42 PM »
thanks..
it work ! :wink:
Keep smile...
see the variables
« Reply #7 on: March 04, 2005, 06:05:50 PM »
You're welcome; cheers.
