Author Topic: exploding a ssget  (Read 2426 times)
DEVITG
exploding a ssget
« on: October 24, 2004, 02:12:24 PM »
I have this code parta to selecte all POINT on a drawing
(DEFUN SELECIONEPUNTOS ()
;;;  (SETQ PUNTOS-EJE-X (SSGET "X"
(setq PUNTOS-EJE-X (ssget "X" '((0 . "POINT"))) )
(SETQ CANT-PUNTOS (SSLENGTH PUNTOS-EJE-X))
So I have the selection set , and the number of point on that selection.
QUESTION
How do I get all the entitys names and the x,y,z coordinates of each poitn
exploding a ssget
« Reply #1 on: October 24, 2004, 02:28:33 PM »
You need to iterate through the selection set and get the insertion point from each one.
(setq index 0)
(repeat (sslength PUNTOS-EJE-X))
(setq DXF10 (cdr (assoc 10 (entget (ssname PUNTOS-EJE-X index)))))
;;;add your code here
(setq index (1+ index))
David Bethel
exploding a ssget
« Reply #2 on: October 24, 2004, 04:05:23 PM »
I take a litlle different approach;
(defun SELECTPOINTS (/ ss i en ed ip fl)
(and (setq ss (ssget "X" '((0 . "POINT"))))
     (setq i (sslength ss))
     (while (not (minusp (setq i (1- i))))
            (setq en (ssname ss i)
                  ed (entget en)
                  ip (cdr (assoc 10 ed))
                  fl (cons (cons en ip) fl))))
fl)
-David
R12 Dos - A2K
exploding a ssget
« Reply #3 on: October 24, 2004, 06:28:05 PM »
And a little of both:
(defun selectpoints (/ ss en fl)
       (repeat (sslength ss)
         (setq fl (cons (cons (setq en (ssname ss 0))
                              (cdr (assoc 10 (entget en)))) fl))
         (ssdel en ss)))
  fl
exploding a ssget
« Reply #4 on: October 24, 2004, 07:26:46 PM »
And yet another:
(defun SelectPoints ( / ss i ename result )
    (if (setq ss (ssget "x" '((0 . "point"))))
            (setq result
                (cons
                    (cons
                        (setq ename (ssname ss (setq i (1- i))))
                        (cdr (assoc 10 (entget ename)))
                    result
    result
daron
exploding a ssget
« Reply #5 on: October 25, 2004, 07:57:11 AM »
So DevitG, How do you like your code served up: Sunnyside up, Over-easy or over-hard?
