Author Topic: esc key to end loop?  (Read 4228 times)
jcoon
« on: August 24, 2011, 09:36:33 AM »
I have a simple sta/off mtext label test that I can't seem to get to ESCAPE KEY or space bar to reload form.
The test labels selected picked points from an alignment. what I can't get to work is how to hit the escape key or scape bar to exit the loop and reload the form so I can label new points from another alignment.
does anyone have a link that show how I can hit an esc key or space bar to end the loop and  show the form.
I've 'If Chr(vbKeyEscape) = 27 Then
'ThisDrawing.SendCommand "ESC" & vbCr
'Exit Do
'UserForm1.Show
'End If
John Coon
Do
basePnt = ThisDrawing.Utility.GetPoint(, "Select Location to Label: ")
oAlignment.PointLocation basePnt(0), basePnt(1), testStax, testStay
oAlignment.StationOffset basePnt(0), basePnt(1), StaValue, OffValue
strOFF = Format(OffValue, strFormat)
strStation = oAlignment.GetStationStringWithEquations(StaValue)
strText = "STA: " & (strStation) & "\P" _
           & "OFF: " & (strOFF) & "\P" _
If StaValue <> 0 Then
Set mtxtLabel = ThisDrawing.ModelSpace.AddMText(basePnt, dblWidth, strText)
mtxtLabel.Height = dblHeight
mtxtLabel.Rotation = dblRot
End If
mtxtLabel.Update
Loop
Matt__W
  • I like my water diluted.
Re: esc key to end loop?
« Reply #1 on: August 24, 2011, 09:50:40 AM »
Maybe something like this will get you going in the right direction...
Public Sub GetPointLoop()
    Dim SomePoint As Variant
    On Error Resume Next
    Do
        SomePoint = ThisDrawing.Utility.GetPoint(, "Select a point...")
        If Err.Number <> 0 Then
            Exit Do
        Else
            ThisDrawing.Utility.Prompt "Do something here..."
        End If
    Loop
    MsgBox "Show form"
Autodesk Expert Elite
jcoon
« Reply #2 on: August 24, 2011, 10:33:37 AM »
Matt,
Thanks for the help.
if I add the
            Exit Do
end if
it labels one label then reloads the form, before it labeled as many picked location but nevered exited the loop without crashing.
John
jcoon
« Reply #4 on: August 24, 2011, 11:09:19 AM »
I'll see if I can incorporate Matt's or jgr's post
just looking at jgr's I think that might be out of my league for a while
Thanks guys
John
Matt__W
« Reply #5 on: August 24, 2011, 11:43:17 AM »
Option Explicit
    Do
            Exit Do
        Else
            AddText
        End If
    Loop
    MsgBox "Show form"
Private Sub AddText()
    Dim ptEN(0 To 2) As Double
    Dim objText As AcadText
    ptEN(0) = SomePoint(0)
    ptEN(1) = SomePoint(1)
    ptEN(2) = 0
    Set objText = ThisDrawing.ModelSpace.AddText("THIS IS A TEST", ptEN, "12")
    objText.Update
jcoon
« Reply #6 on: August 24, 2011, 11:56:56 AM »
Matt,
Ok ...I think I git it from this post.  Funny....I found an old land desktop routine that did basically the same thing as the C3D and it works fine, and all it has was the On Error GoTo Bye.
I'll make the change to add format from your last post.
Thanks for all your help!
John
' old land desktop
    On Error GoTo Bye
  Do
   Dim varDataPnt1 As Variant
  varDataPnt1 = ThisDrawing.Utility.GetPoint(Prompt:=vbCrLf & "Select Next Point to Label: ")
  objAlign.StationOffset varDataPnt1(0), varDataPnt1(1), dblSta, dblOff, dblDir
    strStaFormat = "#0.00"
    strOffFormat = "#0.00"
    strSta = Left(Format(dblSta, strStaFormat), Len(Format(dblSta, strStaFormat)) - 5) _
           & "+" & Right(Format(dblSta, strStaFormat), 5)
    If dblOff > 0 Then
      strOff = Format(dblOff, strOffFormat) & "' RT"
    Else
      strOff = Right(Format(dblOff, strOffFormat), (Len(Format(dblOff, strOffFormat)) - 1)) _
        & "' LT"
    End If
   strText = "STA: " & (strSta) & "\P" _
            & "OFF: " & (strOff) & "\P" _
    Set mtxtLabel = ThisDrawing.ModelSpace.AddMText(varDataPnt1, dblWidth, strText)
    mtxtLabel.Update
Loop
Bye:
Show
jcoon
« Reply #7 on: August 30, 2011, 04:33:45 PM »
I was able to add some of the info from Matt's post to work with my small routine. I adjusted a existing simple x,y label routine that worked fine and generated an error on the right click or esc and reloaded the form just as I wanted, however I still couldn't get the civil 3D alignment routine to esc to the userform on an error without crashing the drawing. I looked at it again this morning after returning back to work from the hurricane.
I added
If StaValue = 0 Then
GoTo Bye
End If
which generates the error becuase the selected location was not within the alignment and it reloaded the form just like I needed
Thanks for all your help Matt W
John
