Author Topic: Setting the OSMODE Setting  (Read 4308 times)
laison
« on: November 08, 2010, 10:21:29 PM »
When writing code and you get to where you are going to set you OSMODE setting can you set more than 1 setting in the same line?
(setvar "osmode" 1, 2, 4, 32)
[CODE]
[/code]
alanjt
  • Standby for witty remark...
Re: Setting the OSMODE Setting
« Reply #1 on: November 08, 2010, 10:42:05 PM »
You add them.
eg.
(setvar 'osmode (+ 1 2 4 32)) or
(setvar 'osmode 39)
Dropbox
« Reply #2 on: November 08, 2010, 10:54:17 PM »
Given it's a bit coded integer I'd be more inclined to "or" the values together:
(setvar "osmode" (logior + 1 2 4 32))
I tried to rewrite this 3 times so I wouldn't sound like a dick without success; sorry, just sayin'.
shrug_icon_goes_here
alanjt
« Reply #3 on: November 08, 2010, 11:18:46 PM »
No dick, just educating.
Thanks Michael.
I assume you meant: (logior 1 2 4 32)
Dropbox
« Reply #4 on: November 08, 2010, 11:26:11 PM »
yeah sh!t :lol: thanks for being gracious
I'll leave the error so the thread makes sense
David Bethel
« Reply #5 on: November 09, 2010, 06:18:35 AM »
logior makes more sense to me if you your trying to ensure that the new modes were added to the existing osmode setting.
(setq os (getvar "OSMODE"))
(setvar "OSMODE" (logior os 1 2 4 32))
It adds the bit regardless of the current setting.
I think I would stick with the plus just for readability. -David
R12 Dos - A2K
Daniel J. Ellis
« Reply #6 on: November 09, 2010, 08:07:50 AM »
So what  does logior do?
dJE
dJE
« Reply #7 on: November 09, 2010, 08:28:06 AM »
heh, too bad some people dont share that basic courtesy.
David Bethel
« Reply #8 on: November 09, 2010, 08:45:27 AM »
Lets say you want to close a polyline : set the 1 bit in the group 70 flag
(setq flag (cdr (assoc 70 ed)))
Either of these statements work:
(if (/= (logand flag 1) 1)
    (setq flag (+ flag 1)))
(logior flag 1)
Logior's advantage is that accepts multiple tests in a single call.
-David
R12 Dos - A2K
