Author Topic: Who is good in math...  (Read 4255 times)
gile
  • Marseille, France
Re: Who is good in math...
« Reply #15 on: May 30, 2011, 03:09:00 PM »
I'am sorry. It's easier for me to give some lines of code rather than a good explaination in English even i know it's not 'educational'.
Sinc gave the way for the GetClosestPointTo() route, I only wanted to show there was no need to  draw two rays.
And Lee talk about the dot product way before I posted the codes.
huiz
  • Certified Prof C3D
« Reply #16 on: May 31, 2011, 08:09:24 AM »
Yes, but with a full function in front of me I got the message.
Because I assumed the nearest point would return the nearest vertex of a line.
gile
  • Marseille, France
« Reply #17 on: May 31, 2011, 08:26:48 AM »
Look at the code, it uses a Geometry.Line3d instance which has none vertex: it is unbounded.
The Geometry namespace contains plenty of classes (such as points, lines, segments, circular arcs, vectors, matrices, and so on) which aren't DBObject and are provided to solve geometry issues.
